Old 06-21-2011, 11:27 AM
Rodamatic80's Avatar
Member #16191
4X4 problem
I have a 2003 Polaris sportsman 400 and the 4X4 does not work. I have noticed that the 4X4 light never comes on even when you just turn the key to the on position, could this be an electrical problem?
Old 06-21-2011, 02:31 PM
OK01POPO's Avatar
Member #15526
Have you checked to see if you are getting power to your switch? Does your indicator light come on to show that you are in, high, low, and/or reverse? The reason I ask is because I was having the same problem but only when in high gear. My indicator light was not coming on in high gear either. This was due to a bad switch on the transmission. Im going to call it the gear selector switch but I'm sure someone else on hear will know the proper name for it. It is the switch on the transmisson that has wires coming from the shifter to the switch. If the switch is bad then your atv doesn't know that its in gear and the 4X4 will not activate. There is a way to bypass the switch if this is the problem.
2001 Sportsman HO
2 inch lift
28 inch Mud Lites
ITP Wheels
EPI Clutch Kit
Warn winch
Snorkled
Relocated Radiator
Hand Guards
Old 06-21-2011, 02:56 PM
ppolaris1010's Avatar
Member #15104
does your speedo work if not the 4x4 wont work
Old 06-21-2011, 03:55 PM
Member #16191
I am a noob its my first atv. everything on the spedo works tells me the correct gear im in. i checked most of the wiring for loose connections or broken wires found none. not realy sure how to check to see if im getting power to the switch.
Tags
2003, 4x4, problems, sportsman 400 4x4
01 polaris sportsman 400 4x4 problem
03 polaris sportsman problems
03 sportsman 4x4 problems no speedo
04 sportsman 4x4 bypass
2003 polaris speedo 4 x 4 bypass sportsman 500
2003 polaris sportsman spedo bad need 4x4
2011 polaris 4x4 problems
4x4 light not on polaris sportsman
clutch kit for 2001 polaris sportsman 400
how to bypas the polaris sportsman 4x4 switch
how to bypass for a polaris sportsman 600
is the 4x4 on a polaris sportsman controled with the speedo
polaris 400l high reverse indicator light linkage
polaris atv 4x4 switch
polaris sportsman 4x4 2001 issues 400
polaris sportsman 4x4 problems
polaris sportsman 800 4x4 problems
polaris sportsman 800 4x4 switch bypass
sportsman 400 4x4 not working
sportsman 600 bypass kill
