Old 06-23-2011, 03:30 PM
slyder01's Avatar
Member #3440
A-arm Breakage on the XP
I was at Hatfield McCoy for a 4 day ride and had a rear a-arm break. This is the second time the same a-arm broke only this time it caused the a-arm bracket which is welded to the frame to break off as well. There is a weak point where the torsion bar support is mounted onto the a-arm. The a-arm on the opposite side will be breaking soon as you can see the paint is chipped away at the same spot thus showing a weak point. Polaris won't warrant it as they say "what did you hit"...
Now i need to find a welder that i can take my machine to, disassemble that area, and have him do his job. Not to mention I had to ride an 01 magnum 500 for two days that beat the crap out of me,,lol
RIDE ON !!
2010 Sportsman 850 XP EPS
2008 Sportsman 400 H.O.
Old 06-23-2011, 03:38 PM
cwlongshot's Avatar
Sorry for the troubles man!! I gotta tell ya... I could fix that!!!
No issue for a good faber/welder!! Maybe its time to buy yourself one and learn how to use it!!
But don't just fix it, make it better!!
Old 06-23-2011, 04:31 PM
I had a right front break at the weld when mine was new, sorry---welds, you can see the rust in your pictures, its been cracked awhile, thats what mine looked like, mine almost caused a hell of a wreck when it broke
Old 06-23-2011, 05:09 PM
muddywaters's Avatar
Member #15640
If you own a Polaris and use it, you better also own or be a welder.
Old 06-23-2011, 05:50 PM
NineLives's Avatar
Member #11351
So your saying that its normal for a Polaris frames to break ????? Its not a Can Am !!!! I have never had any part of my frame break and I have put it through hell and back.
Old 06-23-2011, 06:00 PM
Stealthepooty's Avatar
Member #6542
In the first pic, I see a grease fitting. In the second pic I see rust and an offset outer shell. Should the grease flow down the length of that tube if enough was pumped in?
_______________________
2010 Polaris 850 XP, Warn XP-30 Winch, KFI Winch Mount, Steel Front & Rear Rack Extenders
My neighbor called the cops because I was playing Radar Love too loud.... they arrested him.
Old 06-23-2011, 06:16 PM
Member #15640
I wouldn't call it normal, but my 97 SP500 frame/attachments were welded about seven times, my 05 SP500HO has been welded/beefed-up about four times, both had/have high miles, close to 15000mi. The first part to break was the rear stabilizer on both mach. I figured out on the 05 that the storage box puts a weak point in the frame. I eliminated it and gusseted the whole rear area, haven't had a problem since. Can-Am's frames are probably chrome-moly like Honda's, Polaris's are mild steel. After almost 40 years of Off-Roading,(Jeeps,Bikes),15 of those years on ATV's and almost 30,000mi. on two Polaris's I would never buy another one, I'll keep the one I have going, but when it gets beyond repair, no way another Polaris. I bought both of my machines new from different dealers, one dealer didn't have a clue about the product they where selling the other dealer was just plain ignorant. I don't know if I'll get into another mach, I'm 60 years old, If I do it will be another brand.
a arms breaking on xp 850
painting 2011 polaris 850 sportsman efi xp
polaris 400 ho stabilizer mount broke
polaris 800 a-arm weak
polaris sportsman 850 ho xp
polaris sportsman a arm breaking
polaris xp atv weak points
sportsman 850 arm breakage
stabilizer bar off a 2011 polaris 400 ranger broke do you need it
