2000 sportsman 500 won't start - Polaris ATV Forum
Old 06-29-2011, 08:41 AM
bigcountry32009's Avatar
Member #16377
Exclamation 2000 sportsman 500 won't start
Ok. This is a unique one. I got a 2000 sportsman 500 that I trying to fix to take out of town with me tomorrow morning. Pull rope assembly came apart 3 yrs ago. Parked it. It was gunna be $1400 in parts alone. Found a slightly used motor out of a 2001 sportsman 500. Swapped motors. Rebuilt the carb, drained gas tank and installed a new sealed maintenance free battery. Due to sitting for the 3 years. Now this used '01 motor will not start without a battery charger attached in the "jump start" mode. Hit the gas one time with it on and it starts like brand new. Checked fire. Got good fire. Motor sounds like it is turning fast enough it should start. Without the charger battery volts are 13.2 with key in "on" position. Then droppes to 11.9-12.3 while trying to start. WITH charger in "jump start" mode volts go up to 14.3, and it fires right up!!! ANYBODY HAVE A CLUE I CAN BUY???
Old 06-29-2011, 08:53 AM
ppolaris1010's Avatar
Member #15104
make sure your throttle cable is adjusted right.it has a saftey in it incase it gets stuck wide open if its out of adjustment it will not spark something to check because you said when you hit the gas it starts.also check your choke make sure it working ok and not plugged up.also check your grounds make sure you didn't forget to hook them back up should be one from the engine to the frame.will it pull start on its own? what did you do with the old engine i need one for parts
Old 06-29-2011, 09:06 AM
Member #16377
I just rebuilt and cleaned the carb so it should be fine. I wouldn't think it would the throttle kill cause I put a battery charger on it it starts fine. I have no pull rope on it. That was the cause of my original motor to go bad!!! Its a sorry design. We put 4 of them on it. Seemed like everytime I used it I bought a new one. And yes the ground wires are on. One from batt to motor. Another from the head to frame. Bout the only thing that MIGHT be good on the old motor would be internals. STARTER DRIVE, FLYWHEEL, STATOR, MAGNETS, SOLINODS, COILS, EVERYTHING IN THE FLYWHEEL HOUSING IS SHOT!!! THE METAL ROD CAME OUT OF THE PULL ROPE WHILE IT WAS RUNNING AND AVTUALLY CAME OUT THE SIDE OF TH HOUSING!!!
Sent from my DROIDX using Tapatalk
Old 06-29-2011, 09:36 AM
Member #15104
do you think the crank is still good thats what i need? did you check the cam on the new motor make sure the exhaust lobe isn't starting to go.hard starting is one of the signs for it im sure sure if the 01 engines had that problem or not i know the 99 and 00 did.only other thing i can think off is the starter is drawing to much amps under a load and causing weak spark maybe and when you put the boost to it it gets enough to fire.
Old 06-29-2011, 09:43 AM
tt425's Avatar
Member #3687
Try tapping on the starter while pushing the start button. I think its your starter. If so you can get a starter from dbelectricial.com for about $45.00 plus shipping. Another thing might be a weak battery causing low voltage to stator.
2008 Dodge Caliper
2010 Chevrolet Equinox
2004 Honda ForemanES 400 4x4
(Currently I don't own a Polaris but I work on them all the time and get to ride cutomers for test rides. Maybe soon I will be a Polaris owner.)
Old 06-29-2011, 02:20 PM
Member #16377
Ppolaris1010- everything should be ok internally. You COULD put a stator, flywheel, and starter drive and it SHOULD run. It was running great when the pull rope assembly came apart on it. It has 2,007.3 miles on it. ALWAYS A RELIABLE MOTOR. Never gave me a problem. Never smoked or sputtered at all. Its a good tight motor, especially with 2,000 miles on it. In my case it was cheapper to buy a whole engine with all that on it. They wanted $1400 for those 3 or 4 parts inside the flywheel cover.
Old 06-29-2011, 02:27 PM
Member #16377
Tt425- the motor turns over at regular starting speed. Tried 2 different brand new extreme magna power batteries. Its like the battery ain't big enough. I looked up specs and the old battery on the old motor had the same 14 ah rating for 10 hrs. I'm beating my head against a wall here. I guess I'm takin the honda instead. It'll give me a week to relax and think about it and give MORE people a chance to enlighten us.
Old 06-29-2011, 03:30 PM
tt425's Avatar
Member #3687
So the motor is turning over with the battery on the machine. But it will not start until you hook booster cables to it. Correct?
Check for spark. It could be weak. If this is the case you might need to test the stator and cdi unit. Another thing would be the ETC(electronic throttle control) out of adjustment. You can disconnect the black wire from the cdi unit. If it fires and runs you will have a problem with the cdi unit,rev limiter, or the ETC. I don't have my book with me, but I have a POLARIS SERVICE Manual like the dealers use that covers 1996-1998 Polaris atv's. I can bring it to work with me 2moro and give you a few more pointers. Don't ride that HONDA it don't have enough horsepower. Just kidding. I will try and help you all I can. Thanks
2008 Dodge Caliper
Old 06-29-2011, 03:40 PM
tt425's Avatar
Member #3687
Test the battery and see if it has 190-210 CCA(cold cranking amps). 14AH is correct. the battery should be a 14A-A2.
2008 Dodge Caliper
Old 06-29-2011, 05:10 PM
clean the pickup coils inside the recoil housing and check that the gap between thm and fly wheel is right and fly wheel isnt all rusty
1997 polaris sportsman 500 wont start
1999 polaris sportsman 500 very hard to start
2000 polaris sportsman 500 cranks fast but wont start
2000 polaris sportsman 500 won't start
2000 polaris sportsman 500 wont start
2000 polaris sportsman wont start
2001 polaris sportsman 500 turns over but wont start
99 polaris 500 4 4 wont turn over
how do i drain the starter motor in my 1999 polaris sportsman 500
how to start a 2000 polaris sportsman 500
polaris sportsman 500 will not start
what to check for when atv polaris 1998 atv will not start
need some help on a 2000 500 sportsman Tjhunter ATV Repair and Maintenance 6 05-11-2011 06:56 PM
2006 outlaw wont start when cold but will start when warm. heavyritefoot Polaris Outlaw 6 05-09-2011 02:42 PM
2000 400 will not start aircrued ATV New Members 2 07-14-2010 07:00 PM
2000 sportsman 500 ganoga ATV Repair and Maintenance 2 03-21-2010 06:27 AM
2000 Polaris sportsman 500 won't start Moldman Polaris Sportsman 2 12-30-2009 11:47 PM
