Idling and Shifting Problem - Polaris ATV Forum
post #1 of 6 (permalink) Old 07-03-2011, 09:40 AM Thread Starter
deerjw's Avatar
I have a 2008 800 that began idling too fast. When you start it the RPMs continue to increase without even touching the throttle. As soon as this started it became impossible to shift into gear. I can shut off the engine, shift it into any gear and start the engine. If I start it in Park it won't shift into any other gear. If I start it in forward or reverse, I can't shit into any other gear. When I start it in Reverse or High, it is running way too fast and I'm sure would damange the motor. Any ideas on what might be causing this would be appreciated.
deerjw is offline
post #2 of 6 (permalink) Old 07-03-2011, 09:47 AM
MUDDIE49's Avatar
Have you tried setting the idle if you can? also check the adjustment on the trottle cable...it maybe wacking your idle settting....Muddie49
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System. 2010 camo
SunPro Temp gauge. 550xp Sportsman
Xbow Gripper mount
~DOWN&DIRTY~
MUDDIE49 is offline
post #3 of 6 (permalink) Old 07-03-2011, 09:50 AM
WalterS's Avatar
I am going to guess: either the temperature sensor for the engine coolant is giving the computer bad data, and/or the TPS (Throttle position sensor) is either faulty or out of calibration.
The high rpms are causing the clutches to spin, which WOULD make it hard to shift. Lower the rpms and it should shift fine.
(You have fuel injection, and not a carburetor)
Were there any changes to anything around about the time that the high idle started? Anything in the repair history that would be significant?
2007 Sportsman 800
1500 miles, mostly at Hatfield-McCoy trails, WVa.
WalterS is offline
post #4 of 6 (permalink) Old 07-03-2011, 10:30 AM Thread Starter
deerjw's Avatar
It is fuel injected. I can't think of any changes. I haven't ridden it in about a month. The last time it ran fine. The temperature was in the low 90s yesterday. It started out with no problems, but after about 5 minutes the high idling and not being able to shift it started.
deerjw is offline
post #5 of 6 (permalink) Old 07-03-2011, 03:07 PM
tps sensor bad or may just need to set tps, need special tools to do it, it tells how in serviice manual
Russ C is offline
post #6 of 6 (permalink) Old 07-19-2011, 03:23 PM
lost cause's Avatar
Other things to check is crack in the boot that goes to the throttle body or the throttle body itself. I had a faulty throttle body from the factory. Replaced it and no problems since.
lost cause is offline
2005 ATP 500 HO shifting problem kaycee ATV Repair and Maintenance 8 04-10-2014 10:34 PM
06 hawkeye problem shifting 06hawkeye ATV Repair and Maintenance 0 05-06-2011 06:02 AM
Sportsman Shifting Problem jsb ATV Repair and Maintenance 3 04-19-2011 10:11 AM
04Magnum330 Weird Idling Problem 04Magnum ATV Repair and Maintenance 6 12-30-2010 06:45 PM
problem shifting gears calvin120860 Polaris Sportsman 9 06-11-2009 05:02 AM
