Engine won't turn off - Polaris ATV Forum
post #1 of 7 (permalink) Old 07-23-2011, 06:47 AM Thread Starter
b_horner79's Avatar
I just bought a 2003 Sportsman 500. It starts and runs good. When I go to turn it off with the key, it wont shut the engine down.
Just wondering if anybody has seen this before.
b_horner79 is offline
post #2 of 7 (permalink) Old 07-23-2011, 07:08 AM
Bruce! is offline
post #3 of 7 (permalink) Old 07-23-2011, 07:11 AM
tt425's Avatar
It sounds like you have a broken ground wire somewhere. If not that it's the key switch or cdi box maybe.
tt425 is offline
post #4 of 7 (permalink) Old 07-23-2011, 08:39 AM
MUDDIE49's Avatar
Yup see it before....ign switch in bad...Muddie
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System. 2010 camo
SunPro Temp gauge. 550xp Sportsman
Xbow Gripper mount
~DOWN&DIRTY~
MUDDIE49 is offline
post #5 of 7 (permalink) Old 07-24-2011, 06:55 AM
Common problem. It could be ground wire, or switch, or cdi. Often times if it's the switch you can turn it off very slowly and it will shut off at about 3/4+ rotation. Sometimes it's the ground from the cdi corroded and not making good contact so that you get intermittent shut offs. Other times it's the cdi itself which will usually show up as not shut off when cold but after warm up and fan cycles through on and off the machine will then shut down as it's supposed to. You just have to try and eliminate the easy stuff first (ie. grounds and switch) and go from there.
polman500 is offline
post #6 of 7 (permalink) Old 07-24-2011, 08:46 AM Thread Starter
b_horner79's Avatar
Thanks for the info.
Gonna see about getting a switch for it.
post #7 of 7 (permalink) Old 07-24-2011, 04:53 PM
gmiller0737's Avatar
I had to replace the switch on both My 02 Sportsman 400 & My 02 Sportsman 500 H.O. if you turn it off slowly it will usually turn off got both New O.E. Polaris switches off eBay same seller around $50 including shipping.
gmiller0737 is offline
Won"t TURN OVER flcowboy ATV Repair and Maintenance 2 12-16-2010 06:39 PM
Can i turn them? djtates125 ATV Wheels & Tires 11 03-24-2010 11:35 AM
02 scrambler 50 won't turn over mdutton ATV Repair and Maintenance 1 10-16-2009 04:54 PM
500 engine wont turn off? detinator131 ATV Repair and Maintenance 2 10-01-2009 10:24 PM
300 2x4 won't turn over Pakman ATV Repair and Maintenance 0 05-29-2009 08:55 AM
