Squeal/high pitch whine - Polaris ATV Forum
post #1 of 9 (permalink) Old 07-31-2011, 06:07 AM Thread Starter
Indypo's Avatar
So while riding through a rough trail with my 08 sportsman 800 for about 15 miles,with 1 mile left to go,the bike starts making this really high pitch gear whine sound. It didn't appear to be loosing power or anything and it would stop once i came to a stop.It didn't matter whether the bike was on 2x4 or 4x4.
Fortunately,I was able to drive back to my truck with no other issues.Once i get home after checking all fluids I test drive it ,the noise is no longer there constantly but there intermittently and when the noise is present if I let go of the gas and and quickly hit it again ,the noise goes away. It only does it in high gear and it won't do it while in park or neutral even if i give it some gas.
Now I can't seem to pinpoint where the noise is coming from ,not sure if it is a wheel bearing,transmission bearing problem or cv. When the wheel bearing or cv go,do you get a high pitch whine noise? Any ideas?Thanks.
Indypo is offline
post #2 of 9 (permalink) Old 07-31-2011, 08:16 AM
first thing I'd check is the belt
Russ C is offline
post #3 of 9 (permalink) Old 07-31-2011, 08:36 AM
jordaman17's Avatar
the clutches wine if your moving down a small incline with no throttle applied i believe
2016 Sportsman 450, Polaris front bumper, running on 26" Kenda Bearclaw htr's.
2010 Polaris Ranger 400, Super ATV Roof, running on 26" Maxxis Zilla's.
(sold August 17th, 2015 ) 5490km 2008 Polaris Sportsman 500 Ho, Polaris Hand & Thumb warmers, RotoPax 4 Gallon Fuel Pack, Custom Made Rear Bumper, PowerMadd Hand Guards, Polaris Rear Work Lights, Ricochet Ultimate Armor, Polaris 3500lb Winch, Rear Rack Extender, Polaris Brush Guard, 3 Headlight Mod, Uni Air Filter, EPI 'patv1' primary clutch spring. All up on Interco Swamplites!
Subscribe to my youtube channel! ---> http://www.youtube.com/user/mudsling...ew=0&flow=grid
jordaman17 is offline
post #4 of 9 (permalink) Old 07-31-2011, 11:23 AM
Tedpilot's Avatar
CVs will not whine. Did you change the gearbox fluid and notice anything wrong? Any hard jolts to the driveline lately? Sometimes dust in the clutch will make a whimsy type of noise but not often.
Tedpilot is offline
post #5 of 9 (permalink) Old 07-31-2011, 02:04 PM
lost cause's Avatar
The U-joint in the rear prop shaft can go bad and cause a squeeling noise. Check and see if it is solid. If a CV was bad it would pop or click but not whine. Let us know what you find.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N AIR FILTER
POLARIS 3500 WINCH
POLARIS OEM BELT
STOCK EXHAUST
lost cause is offline
post #6 of 9 (permalink) Old 08-03-2011, 05:01 PM Thread Starter
Indypo's Avatar
Thanks for all the replies.It is not a belt problem,already put a new one and same noise.I had some time to put the atv on jack stands yesterday and could not replicate the noise but after a test drive here's the best way to describe the noise:
When our machines slow down or go downhill they tend to make a whining sound when the throttle is released correct?Well when i release the throttle and hear the whining sound and quickly apply throttle the whining still remains and even gets louder until i release the throttle ,reapply and the noise disappears.If i hear the whining sound when i release the throttle and let it quiet down before hitting the gas again , it makes no noise.I am starting to think it could be the one way bearing in the primary clutch causing the whining sound to linger and amplify.Any ideas?
Indypo is offline
post #7 of 9 (permalink) Old 08-03-2011, 05:37 PM
mstermechanic907's Avatar
Send a message via MSN to mstermechanic907
this sounds like its the one way sprag clutch,i had to replace this clutch for a customer and this fixed him up.let us know if you still need help as there are alot of smart people here on this forum.
mstermechanic907 is offline
post #8 of 9 (permalink) Old 08-04-2011, 05:07 AM
Yeah, sounds like the one way clutch to me.
Hey mastermechanic, my 06 800 has squealed some on descents when off throttle since I picked it up a couple years ago. I pretty much knew that's what was doing it and it stops when a little throttle is applied. Question is, do those clutches need periodic dis assembly, cleaning and lube or is that just the nature of the beast? Or....is it just the belt slipping a little and squealing when the EBS is holding back?
polman500 is offline
post #9 of 9 (permalink) Old 08-04-2011, 06:06 AM Thread Starter
Indypo's Avatar
Took the belt housing cover off and i noticed when the atv runs in 'park' the secondary spins a lot but does not in gear.After removing the belt, I tried to rotate the one way bearing clockwise and it spins freely but locks counterclockwise.Shouldn't it be the other way around? I also noticed some play with the bearing,maybe it needs trusthwashers.Is this normal?
Indypo is offline
Crankshaft/flywheel nut thread size and pitch auditech ATV Repair and Maintenance 7 10-08-2014 05:27 PM
Sportsman 500 squeal Zachryw ATV Repair and Maintenance 3 03-01-2011 05:58 PM
07-08 700 efi Ranger High Pitch noise Big D ATV Repair and Maintenance 1 11-24-2010 03:15 PM
800 belt squeal renorider Polaris Sportsman 8 04-11-2010 02:54 PM
06 800 down hill squeal? polman500 Polaris Sportsman 3 03-03-2010 04:51 AM
