07-31-2011, 07:43 AM
Member #4587
2005 Sportsman 500 H.O. Problems
So I'm riding along and my 2005 Sportsman 500 H.O. dies. I start it up and give it the gas and it blubbers and dies again. It wil start up and idle smooth as can be but when I give it some gas it blubbers and dies everytime. I'm running a K&N air filter and pre filter on the carb. (it's not fuel injected) that was cleaned and oiled before I went for a ride. Any ideas why?
*** PROBLEM SOLVED *** I took the top off the carb and found out that the e-clip came off the carb needle and the slide was not moving up or down. When I gave it gas it would flood out and die. Put the e-clip back on the middle notch of the needle and put the carb back together and it fired right up and runs like a champ.
07-31-2011, 01:56 PM
Member #858
try checking your gas filter and see if has any Vaccum leaks...
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System
SunPro Temp gauge
Xbow Gripper mount
~DOWN&DIRTY~
07-31-2011, 08:39 PM
09-06-2011, 12:43 PM
Member #18420
I have the exact same year and make and mine is doing the samething. Did you find anything out. Thanks
09-06-2011, 01:22 PM
Member #10881
i would adj the etc(throttle cable) cable
09-06-2011, 02:26 PM
Member #18420
thanks
09-06-2011, 02:56 PM
Member #18429
I have a 2006 sportsman 500 HO EFI. Just bought it for the up comming deer season. Its been running great and now all of a sudden the engine backfires when you let off the throttle and won't idle. You have to keep the engine @ 3000rpm to keep it running. Can any one help me figure this problem out?
Member #18430
hi im a new guy here but this happen to the wifes quad.. it ended up being water in the fuel..someplace she got gas or was water in the gas can.. just a thought
09-06-2011, 03:11 PM
Member #18429
I've tried taking all the fuel out and checking the filter, pulling the spark plug and regaping(looked great), checked the spark plug wire and coil for any abnormal signs and nothing there, pulling the injector(inspecting and looked good), cleaned the air flow sensor, new K&N filter, inspected for any vacume leaks and added fresh fuel. I gave the thing a bath after playing in the mud alittle bit and thought I may have gotten something wet but its been 8 days now and whatever it is should have dried out.
09-06-2011, 04:57 PM
Member #7294
Not sure if this is the same but my 05 500HO had problems missing or running bad between 20=30 mph, checked with a Polaris dealer who drove it and he said he had no idea but he would guess it was not fuel related, waited 2 weeks for him to look at and hadn't gotten to it so picked it up and worked on it myself , went 2 sizes bigger on the main jet and problem solved.
2005 polaris 500 leaking fuel, 2005 polaris sportsman 500 carburetor cable, 2005 polaris sportsman 500 h.o. problems, 2005 polaris sportsman 500 ho, 2005 polaris sportsman 500 ho dies when taking throttle, 2005 polaris sportsman 500 ho problems, 2005 polaris sportsman 500 ho wont take throttle, 2005 polaris sportsman 500 problems, 2005 polaris sportsman 500 spark problem, 2008 sportsman 500 dies when give gas, carburetor for 05 plaris sportsman 500, fuel injection for sportsman 500 problems, i am trying to start my polaris sportsman 500 and it just keeps backfiring, k&n air filter for 09 polairs 500ho, polaris 2005 800 sportsman injector problem, polaris 500 ho 2005 carb adjust, polaris 500 ho problems, polaris sportsman 500 ho problems, sportsman 500 dies when give it gas, what mm carb do i need on a sportsman 500 ho
