Old 08-28-2011, 01:30 PM
hugeyota's Avatar
Member #1526
12345
Old 08-29-2011, 05:41 AM
believe it for the speedo memory, clock most likely in case other battery goes dead youl still know the time, wont start but at least youl know the time,LOL
Old 08-29-2011, 01:07 PM
guruerror's Avatar
Member #17443
Clock? Didn't see that on there, but I've got the 9volt hookup too.
...the chrome won't get you home.
CNTRY
Old 08-30-2011, 04:08 PM
my 850 has a clock, not sure about the 800
Old 08-30-2011, 04:52 PM
Hawkeye 007's Avatar
Member #8077
Who's on 1st?
2011 Red Touring 850
Ricochet A-Arm guards
Old 08-30-2011, 05:06 PM
guruerror's Avatar
Member #17443
I thought 'What' was on first?!
CNTRY
Old 08-30-2011, 05:31 PM
Member #8077
No, what's on 2nd.
Old 08-31-2011, 08:45 AM
itsfit's Avatar
Member #1726
Idontknow!!! 3rd base! I believe all sportsman's have a clock with the key on push the reverse override button in and it will change with each push refer to your owners manual to set the correct time
2008 Sportsman 500 HO Polaris winch, front and rear bumbers, rear rack extenter
Old 08-31-2011, 08:59 AM
Member #8077
Good job, itsfit!
Old 08-31-2011, 09:02 AM
antoniodef's Avatar
Member #11247
No clock on my 11 500 SP. I never saw a 9 volt hook up either. Saw the two accessory wires and the diagnostics hook up when wiring in a winch, headlight mod and HIDs. Maybe it has something to do with EFI? The new 400s & 500s are carbed, but the 800s and XPs are EFI.
2011 Trail Boss - HIDs SOLD
2002 polaris predator 500 volt
9v battery connection polaris ranger xp 2010
atv battery hook up
battery hook up for polaris sportsman 325
how do u hook up wires on a 4wheeler
how to hook battery up polaris 2009 4 wheeler
how to hook up a battery in a foour wheeler
how to hook up battery on 05 rincon
how to hook up battery on polaris sportsman
is polaris magnum 325 6 or 12 volts
polaris 450 atv is it a 12 volt system
polaris 700 sportsman battery hook up
polaris atv: battery connection
polaris battery hook-up
polaris battery hookup on an atv
polaris mv7 roll bar
polaris ranger with 9 volt battery
polaris sportsman 9v battery
what is 9v battery hookup on polaris ranger
where to hook up radio on 06 polaris ranger xp?
12 Volt Power Source Camo850xp Polaris XP 6 08-06-2011 06:20 AM
9 volt battery connector under pod?? hoffauto Polaris Sportsman 7 10-12-2010 05:30 PM
replaced starter- battery cable still melting conections and dead battery mcmarkrazz Polaris Sportsman 4 09-19-2010 07:20 PM
winch hookup scott09 ATV Repair and Maintenance 5 04-09-2010 10:35 AM
04 Polaris Sportsman 700- Battery cable melted battery?? clarksofky Polaris Sportsman 3 12-24-2009 06:45 AM
