09-05-2011, 07:35 AM
Member #17280
broken frame
jus wondering.. does polaris have any kind of recall on broken or cracked frames?.. i have welded up mine twice now and jus found another crack after a long weekend of rideing.......not complaining just wondering if i should just weld it up(which i will probley do) or see if it is some kind of safety issue they r voulunterily correcting...anyone have this problem?
it is a 2005 sportsman 800......
thx guys
09-05-2011, 08:02 AM
I have read of a number of guys having this issue.
If It where me I would look closely at how and where It cracked. Then repair it so its stronger than before, not just melted back together... Remembering that welding can make surrounding metal brittle and stress. Make long repairs spreading out the load. If in a corner brace it bigger and if a duplicate exists on opposite side, add a gusset there as well.
The other side of the coin. Look into if the fault lies with you. Arte you jumping or otherwise abusing the machine?
09-05-2011, 10:01 AM
Member #17280
i work for a auto dealership in the collision dept and i have the skills and equipment to repair this rite and properly reinforce it.. i just know that the manufacturer would be very concerened about a structure failure like this and could also tell if it was from normal use or a product of abuse.... i have owned my atv since new and have never crashed it bad(normal bumps and bruises yes) and have never used it out of the norm... but yes it does have high mileage (12 000 kms) so if this is a product of high mileage than alot of u on here that do alot of rideing mite want to keep a eye on your chasis around your suspension anchor points......if there is any more interest in this topic i will post pics before i repair it,,,,thx
09-05-2011, 10:32 AM
Member #12678
I would like to see a photo,... just for future reference.
2007 Sportsman 800
1300 miles, mostly at Hatfield-McCoy trails, WVa.
09-05-2011, 12:26 PM
Member #14149
hey where did it brake at. I had my 800 touring frame brake rite over the left front strut a few months ago at about 3800 miles. Polaris fixed it under warranty. Can u post a pic of where it broke
09-05-2011, 05:18 PM
Member #17280
i will try to post pics tommorow.. it broke in 2 places 1st was on the shaft that mounts the transmission behind the battery box.. and the second was at the bottom of the lateral peice that runs from the top of the frame to the bottom of the frame behind the rt ft wheel
2011 850 xp frame crack, 850xp frame cracking, broken atv frames, broken polaris frame, frame problems on polaris atv, how to fix a broken atv frame at a suspension point, polaris 850 cracked frame, polaris 850 frame issues, polaris 90 frame breakage, polaris atv frame problems, polaris atv frames, polaris broken frame, polaris frame extension problem, polaris predator 500 broken frame weld, polaris predator gussets, polaris sportsman frame gusset, polaris sportsman frame repair, polaris sportsman xp broke frame repair, predator 500 cracked frame, sportsman 850 xp frame gussets
