Old 09-06-2011, 04:20 AM
jrm's Avatar
jrm jrm is offline
Member #18403
500HO - Headlight replacement help needed
2011 Sportsman 500 H.O. model... One of my headlamp bulbs is out. Sounds like a simple replacement, but I am stuck and could use some help.
Do I have to replace the entire harness/bulb? (expensive!) Or can I just replace the bulb itself?
The bulb looks like a standard halogen and I guess I could find the same bulb. However, I cannot figure out how to get the build out of the harness. It is stuck in there pretty tight. Is there a trick to removing the bulb?
The owner's manual simply says to "remove the headlamp and install the new headlamp." Doesn't say how or even what to replace it with. The specs only show it is a "single beam 50w" bulb.
The harness is marked "GE 886" - is the harness and bulb a one piece unit? This would mean that a bulb replacement is roughly a $45 cost. Seems there must be a less expensive way.
Any help would be very much appreciated.
Old 09-06-2011, 04:32 AM
Old 09-06-2011, 04:35 AM
jrm's Avatar
jrm jrm is offline
Member #18403
Thanks for the welcome, Bruce. I am new to ATVs and have been lurking here for a few weeks. This place is a great resource.
Old 09-06-2011, 05:11 AM
racer37l's Avatar
Member #5629
Welcome!
Is the lamp you need to change in the pod or one of the lower lamps?
Con
Old 09-06-2011, 05:32 AM
jrm's Avatar
jrm jrm is offline
Member #18403
It is one of the lower lamps. I removed the unit from the headlight container (simple twist). I also removed the "harness" from the wire (clip). I have a black, right angled, piece of plastic with two prongs one one end. The other end has a bulb with two contacts that seat into the black plastic. The bulb will not pul out of the plastic "harness." I am starting to think they are one piece and have to be replaced together.
Old 09-06-2011, 06:17 AM
Member #1958
It's all one peice...take it to any auto parts store.
Old 09-06-2011, 06:28 AM
racer37l's Avatar
Member #5629
Look at Hit-the gas.com
Their a sponser here and show you can get the bulb separate.
I did get bulbs for my bike at auto parts store. They should be fog light bulbs.
Con
Old 09-06-2011, 05:48 PM
jrm's Avatar
jrm jrm is offline
Member #18403
Thanks for the help. Seems and "886" bulb is the bulb and plastic assembly all in one. I am not sure what some online retailers are charging $45 for, but my local auto parts store has the item for $8. I am glad the solution was that simple.
Old 09-06-2011, 07:09 PM
antoniodef's Avatar
Member #11247
You found one? Dang it. I was gonna sell you one for $20 , and even pay shipping. JK. Glad you figured it out.
Put a little dielectic grease where you plug the harness into the bulb. It waterproofs the connections and helps it last longer.
2011 Trail Boss - HIDs SOLD
2006 polaris sportsman replacement headlight bulb number
2007 polaris sportsman 500 ho headlight bulb
2009 polaris sportsman 500 ho headlight
2011 polaris 500 headlight
ge 886 bulb cross reference
headlight bulb replacement guide for polaris sportsman
how to change headlight bulb in polaris sportsman
how to change the head lamp on a polaris
how to replace a lamp in atv
how to replace headlight on polaris outlaw 90
instructions on how to change a polaris 300 headlight bulb
polaris 886 bulbs
polaris atv headlight replacement
polaris sportsman 500 headlight bulb
polaris sportsman 500 ho headlight loose
replacement bulb for polaris sportsman headlight
replacing headlight pod on a polaris atv
what type of bulb does a 2008 polaris outlaw 525irs headlight take?
what type of bulb is in a polaris 700
headlight on 525 irs dizzydd101 Polaris Outlaw 3 04-02-2011 07:49 AM
3-Mod Headlight macdaddy ATV New Members 2 02-05-2011 04:42 AM
How many here have done the headlight mod? 03 600 twin Polaris Sportsman 44 01-07-2011 08:24 AM
3 headlight mod + HID - 500HO?? WilliamBos Polaris Sportsman 15 07-28-2010 11:17 AM
WTB 2006 Sportsman 800 headlight assemblies or gauge pod/headlight Angel of Death ATV Parts for Sale 1 09-06-2009 08:15 AM
