09-06-2011, 03:42 PM
Member #18429
2006 POLARIS Sportsman 500 HO EFI backfires
New to this but love to ride. My 2006 500 H.O. EFI 4X4 Sportsman was running great, sprayed off some mud and now will not idle. It will just cut off. I have to hold the throttle on at 2800-3000rpm and when you let off it back fires. I normally enjoy fixing things but this is my 1st ATV and the closest polaris dealership is not only an hour away but the mechanic they had has quit and eventhough it's been over two months, he hasn't been replaced yet. So I'm reaching out to you all for some help if possible. Any ideas?
09-06-2011, 04:19 PM
Welcome!!
I was just down in your neck of the woods over the weekend!!
Sounds like you got some water issues!! You need to get it dried out!! You can do this will mother nature, let it sit out in the sun or in a warm environment for a while. Once its dried out it will return to normal. THEN you need to better water proof it. I like die electric grease. Put it on all electrical connections and the porcelain part of the plug(s) in the rubber boots that go over the plugs.
06 polaris sportsman 500 efi running problems, 06 polaris sportsman backfires, 2006 polaris 500 backfire, 2006 polaris 500 sportsman forum, 2006 polaris 550 ho, 2006 polaris ho efi sportsman 500cc 4x4, 2006 polaris sportsman 500 efi backfires, 2006 polaris sportsman 500 efi cutting back, 2006 polaris sportsman 500 efi sputters and backfires, 2006 polaris sportsman 550 ho backfire, 2006 sportsman 500 cutting out, polaris 500 backfiring through intake, polaris efi backfire problems, polaris sportsman 500 back fires, polaris sportsman 500 backfires, polaris sportsman 500 efi backfires, polaris sportsman 500 efi backfiring, polaris sportsman 500 fuel filter runs dry, sportsman efi backfire, troubleshooting a polaris atv backfires
