11-30-2009, 05:32 PM
Member #2139
04 Polaris Sportsman 700- Battery cable melted battery??
Ok, this is the second time in two months. First time it happened, I had just trailered my 700 and needed to restart it. Would not restart and when I checked the battery the positive cable had melted off the battery.
Replaced started solenoid,battery, and the positive cable. Everything was fine. Did a few small rides and no problems. Took it to Polaris for a TSB and asked them to check the electrical while it was there. They only saw that the fan switch needed replaced( it quit working on a ride and we had to override it). Paid to replace the switch.
Now, Hubby took the 700 on a ride this weekend and it melted the cable again!!This time he was using the winch when it happened.
Does anyone have any ideas where to start looking or have had this problem??? Hate to pay Polaris again when the did not see a problem just last week!!
11-30-2009, 05:51 PM
12-23-2009, 08:04 PM
Member #1620
Looks like it's been a while since you posted this question. I haven't logged in for a while.
I have an '04 700 and have found that Warn has a recall on the relay that controls the winch. Mine was installed at the dealer. Your problem was one of the symptoms, the worst outcome being a fire. I emailed them from their website and they sent me a new relay, no questions asked. The relay is found in the back under the left side of the rack.
--C
12-24-2009, 06:45 AM
Member #2139
Thank you C
I did just look that up and submitted my form. Thank you for the information. I hope this solves the problem but it can't hurt to try it!!
Heather
04 polaras, 04 polaris 700 will not start ?, 700 polaris will not start, atv battery cable size, atv battery cables, atv battery terminal melted, battery cable boot melted polaris atv, battery cable boot polaris 700 sportsman, battery size for 04 sportsman 800, melted battery terminal on polaris sportsman 700, polaris 700 will not start, polaris battery cables fire, polaris sportsman 700 battery, polaris sportsmen 700 will not start, polarismelted battery terminal, sportsman 700 polaris atv battery, what is the battery cable size for atv, what size battery battery for polaris 700, what size battery is on a polaris 700 atv, what size battery is polaris sportsman 700
