Old 12-07-2009, 07:54 PM
sneakycleats's Avatar
Member #2213
2008 Sportsman 500 goes click
My 500 does not want to engage the starter. Friday 9 degrees outside and solenoid would click when I tried to start it. Tried back up recoil starter and could't budge engine. Later in day when temp got abouve freezing it started up fine with electric start. Had it up in the fields loading deer and it died. Elecric start would only click the solenoid and not crank but lighs and fan was working. Back up recoil worked fine. Brought it home and charged battery for 24 hours. Electric start just clicks the solenoid but will not crank engine. All the while the electric start does not work lights work and instrument cluster work . Is this a bad battery, solenoid or starter? Help!
Old 12-07-2009, 08:09 PM
since you are hearing the solenoid click, that shows it is working(most if not all of the time). since the starter didnt work, and then it did, and then it didnt again, i think it is okay there too. once the starter goes, it is done, it doesnt work again until it is fixed. (fyi, almost always you can rebuild a starter for half of what a new one cost)
which leads us to the last of the three, and the most common to fail. may i ask how old this battery is? how often is the atv used?
just because you charge a battery and it has 12V doesnt mean it will start the machine, or start it more then once. i common problem with batteries that are shot is if you charge it to full charge, start the machine up, turn it off, and try to restart in 5 mins later and it wont start. your battery probably still had the volts to run the lights and fans, but not the amps to start the machine. first thing to do is to charge it to full charge, but do not overcharge it, and then take it to a battery shop so they can do a load test. if it fails the load test you need to buy a new battery. the shelf life on these thinks is only about 2-3 years. hope that helps some
Old 12-07-2009, 08:26 PM
Member #2213
Sportsman 500 not starting
Thanks blueline15. All of that makes complete sense. I was hoping for the battery to be the problem and thought it was the most susceptable part. It is the original battery that was in it when I bought it August 08. That battery is probably two years old or close to it so that makes sense. I will give it a try and let you know. Thanks again!
Old 12-07-2009, 08:33 PM
no problem. a load test at a battery store shouldnt cost you anything. if the battery is charged it only takes like 10 seconds to do. battery brands can make a difference too in their length of life. has the battery or machine sat for longer the a month or so without being charged or used? let me know what you find out. good luck
Old 12-07-2009, 08:41 PM
Member #2213
I have kept the machine pretty active since this August. At least 4 to 6 hours every other weekend and now during hunting season 2 to 4 hours every weekend. However, through the spring and summer not much activity. Get it out on a weekend once a while and let it run 15 to 30 minutes. But now that I think about it, the last two weeks it seemed to be dragging a bit to get started. I will keep you posted.
Old 12-07-2009, 08:47 PM
sounds good. a battery tender is worth their weight in gold. if you dont know what they are, they charge your batter and keep it charged while you are not using it. if floats the charge without overcharging your battery and boiling the acid inside. your batt looses about 1% of charge every day its not used. once a battery gets to about only 60%-70% charge, you start to get corrosion on the plates inside, which means less contact surface with the acid and less cranking amps. once the corrosion sets in, it is almost always inreversiable and the battery must be replaced. a $40 battery tender solves that problem and is worry free to leave on and charging for weeks at a time. it common to see battery tenders extend the life of a battery by 1-3 more years
Old 12-18-2009, 08:16 AM
Member #2213
Battery not the deal. Soleniod appears to be working so we ordered a new starter today. DID NOT order from Polaris dealer. Ridiculous! They wanted $435. My son-in-law found one for I think he said around 70. Will let you know how this friggin saga ends.
Old 12-18-2009, 03:15 PM
atvjunkie821's Avatar
Member #2326
Check to make sure you have a good connection with the battery cables, I have had one to have a corroded cable that would click but not carry enough current to actually turn the the starter. Also Try tapping on your starter's end as your attempt to start it. Brushes will get corroded not make good contact, a slight tap will set them in. Disassemble the starter and check the brushes and where they make contact on the armature. Some sand paper might be all that you need..
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
YouTube Channel:www.youtube.com/user/tinkerman01
Old 12-18-2009, 09:24 PM
chuckraduenz's Avatar
Member #206
just cuz the solinoid is clicking. dosent really mean its working. last yr my battery and solinoid whent out at the same time. the solinoid clicked but it wasent letting power though to trip the starter. the same thing happend on a lawn mower 2 weeks ago. battery was good. starter was new. along with the solinoid. but the solinoid was bad. 12.xx at the battery. .50v on the starter side of the solinoid. solinoid was replaced. it fixed the issue. by pass the solinoid see if it starts that way.
2008 polaris sportsman 500ho carb (cash paid)
home made 54" snow plow
3000lb warn winch
6 911ep led warning lights and a ls12
LED taillights & work lights
K&N air filter
P-X-T tires and alum rims
hand/thumb warmers
also have:
fimco boom sprayer with lock and ride mounts made by me
pull behind grader and box scraper
just added the rotopax gas packs to the front of my wheeler
1998 polaris 500 ho just clicks when trying to start
2008 polaris sportsman 500 ho battery removal
2008 polaris sportsman 500 ho electric start clicks
2008 polaris sportsman 500 wont start
2008 polaris sportsman 500 wont turn over
2008 polaris sportsman battery
2008 sportsman 500 battery removal
2008 sportsman 500 not charging
i replaced the solenoid on my polaris 700 and it doesnt work
my polaris 2008 500ho starter only clicks
polaris 500 clicks but starter does not engage
polaris 500 sportsman clicks when starting
polaris solenoid just clicks when trying to start
polaris sportsman 500 starter klicks
polaris sportsman wont start just clicks once
sportsman 500 starter clicking
sportsman bad solenoid
what battery comes in a 2008 polaris sportsman 500
where is my battery on a 2008 polaris sportsman
youtube on 2008 sportsman 90 will not crank
