Old 10-08-2011, 11:00 PM
Mastroz's Avatar
Member #19400
Breakin - 2011 550 EPS
Is there any certain things I should do for breakin for my ATV? I just got it and everything. anyone know the top speed of the 550eps ? just wondering.
thanks!
Old 10-09-2011, 03:29 AM
North Branch's Avatar
Member #1986
Well, your manual should have instructions for the proper break in period. It is important to also break the belt in properly.
With that said, the manufacturers tend to be very conservative in their break in procedure. Here's how I break in my ATV's...
For the first 25 to 50 miles, take it pretty easy. Use both high and low range at the proper speed. No WOT.
For the next 50 miles, give it an occasional quick burst to 1/2 to 3/4 throttle for a second or two, and then leave off and go easy for a while. (I would change out all the fluids at 100 miles)
For the next 100 miles, give it an occasional quick burst to WOT for a second or two, and then let off and go easy for a while.
After 200 miles, it should be pretty broken in. However, I would stay away from long, extended periods of WOT for a couple hundred more miles.
The trick with a new engine is to get it briefly hot (not scorching hot), and then let it cool down. The allows everything to expand correctly, and contract correctly, and should seat everything nicely.
Essentially, don't baby it, but don't beat on it until it's ready for a good beating.
Old 10-09-2011, 06:13 AM
Wheelie Man's Avatar
Member #15100
Break it in how you plan to ride it. If you plan to ride it hard ,Run it hard from the start. If you plan to putts around on it all the time than putt around on it from the start. when they built it, they ran it. Ride it how you want.
Old 10-09-2011, 07:30 AM
Mastroz's Avatar
Member #19400
thanks guys.. i'll just kinda ride it like I usually ride it. I don't usally just hammer on it anyhow. I can't wait to run it!!
One last thing, when I have 4x4 on, it will go into reverse 4x4 right? the guy told me other other way around. and hold the yellow button in while i do that
Old 10-09-2011, 07:50 AM
Member #1986
Yep, your quad, ride it like you want. Certainly won't hurt to just... drive it normal. Going the other route and beating on it while it's new... will hurt it.
That yellow button on the XP's works different than the older Sportsman's. On your machine, it will kick into AWD when needed in reverse without holding that button. On your machine, that button simply overrides the speed limiter in reverse.
Old 10-09-2011, 11:52 AM
Mastroz's Avatar
Member #19400
ahh just to go over a certain speed in reverse.. hold that and go fast :-D nice.. thanks alot!
Old 10-09-2011, 06:58 PM
bobx2's Avatar
Member #14376
I would recomend that you ride it like normal after you put 10 hours or so on the engine. Many different schools of thought on this subject. Make sure you change your motor oil after 20 hours.
There is another thread posted here a day or so ago that explains why you don't ride it hard until you get some hours on the engine. I go by hours instead of miles.
Old 10-09-2011, 07:06 PM
Ghost Rider's Avatar
Member #8854
thanks!
The top speed is 60 - 65 mph. Ive had my 550 EPS up to 65 mph and its nice and smooth at that speed.
I will warn you, the stock tires are junk. On my second ride the side wall on one of the stock tires blew out, and the dealer wouldn`t cover it. So i bought a new set of BigHorn tires, there much better than the stock tires.
2011 Sportsman XP 550 EPS
Front And Rear Rack Extensions, Rear Lock And Ride Box With Back Rest, Heated Hand Grips, winch, Fender Extensions, Front And Rear Bumpers, HID Lights, A-Arm Guards, Low Lock And Ride Windshield, Maxxis BigHorn 2.0 Tires.
Old 10-10-2011, 02:42 AM
Thebeatontrack's Avatar
Member #18811
The manual has pretty specific instructions for the break- in. I'm following their instructions I'm sure it was created by a bunch of over paid engineers, plus I don't want any problems. Just my two cents.
2012 Sportsman Touring 550 EPS
Polaris 2500lbs winch kit
KXP Ratcheting Rhino Grips
Reverse override switch
Wish List:
Cobra bush guards
Symtec heated grips and thumbwarmer
Rack extenders
Old 10-10-2011, 03:12 AM
cwlongshot's Avatar
Morning Mastroz,
North Branch gave it to you straight but Bob also brings up something I completely subscribe to... the first 10 hours are of the utmost important. I also like to change the oil and filter at 10 hours. Then again at 50, then in normal recommended intervals...
Oh and one more thing... The whole "Drive it like you stole it" thing is plain stupid... Just my 2cents.
Good luck,
2011 polaris 550 oil change procedure
2011 polaris 550, how to change a wincg switch
2012 polaris 550 eps reverse overide
breakin atv
engine oil change 2011 polaris sportsman 550 eps
how fast should a 2012 sportsman 400 go with a 250 lb person
how to get more speed out of my 2011 polaris 550
polaris 550 break in period?
polaris 550 eps
polaris 550 eps breakin service
polaris 550 eps how fast?
polaris 550 eps oil change kits
polaris break in instructions
polaris eps kit manual
polaris sportsman 550 increase reverse override speed
polaris sportsman 550 low range speed
polaris sportsman 550 top speed
polris 550 top speed
what is the speedo/reverse override on a polaris 550?
2011 Sportsman 500 replaced w/ 2011 Sportsman 800 EFI bulldawg87 ATV General Discussion 4 09-24-2011 03:41 AM
2011 Sportman 400 or 2011 Kingquad 400fsi 2000xplorer250 ATV Purchasing and Price 19 08-15-2011 05:18 AM
Rebates on Nearly all 2010 and 2011 Models March 1st, 2011 cmharcou ATV Purchasing and Price 0 03-02-2011 02:56 AM
Breakin period nmpolaris ATV General Discussion 8 03-17-2010 12:09 AM
