AWD - Polaris Sportsman 500 - Polaris ATV Forum
Old 11-02-2011, 06:11 PM
ocala500's Avatar
Member #12479
Hey all, i have done a bunch of searching already but haven't quite found the answer I am looking for.
I am quite certain the issue with my 500 is electrical. Someone that had the 4-wheeler before me tried splice different things in the front of the atv, and I am not familiar with electrical stuff. I basically think they were trying to splice stuff to get the 4-wheel drive to work, without fixing the issue. I want to fix the issue.
So, what I do know. I have a 2002 500 HO. The light for AWD does not come on. The brake light does not come on. Apparently, they are both attached to the same fuse. I am thinking the fuse is my issue, but I have no clue where the fuse is.
Thoughts? I really appreciate your help!
Old 11-03-2011, 08:14 AM
Bamper's Avatar
Member #19342
There's actually only 1 fuse on you model and its for the accessory plug there are 2 circuit breakers bu those are for the fan and looks like the lights. I know some models if the speedometer isn't functioning correctly then it wont go in 4wd. Ill pm u the service manual for is the wiring diagrams are in the back.
Old 11-03-2011, 12:06 PM
ocala500's Avatar
Member #12479
i have the clymer's manual, which does have wiring diagram, but i suck at reading them. It appears TO ME that one fuse does play a part in the AWD, but again, that is only to me. My speedo is working too.
Any other thoughts on what might be causing the issue?
Old 11-05-2011, 05:31 PM
ocala500's Avatar
Member #12479
update - I apparently was an idiot and forgot to plug in my brake light a few months ago, so my brake light works.
still haven't figured out issue though
Old 01-08-2015, 01:20 PM
kingkwik's Avatar
Member #40484
I have the same problem qith my 03 500ho. awd just stopped all of a sudden. battery and wrench light was flashing but found out it was a loose battery terminal. I thought I fried a fuse only to find it doesn't have any.... did you find a solution and if so what is it?? thanks
Old 01-12-2015, 09:07 PM
grhof's Avatar
Member #48815
2002 Sportsman 500 AWD Not Working
Did you ever figure out what was the problem? I have the same model and can not get the awd light to come on or the awd to work
1999 polaris sportsman 500 circuit breaker
1999 polaris sportsman 500 circuit breaker#gsc.tab
1999 polaris sportsman 500 fuse location
2002 polaris sportsman 500 fuses
2002 polaris sportsman 500 wiring diagram
a polaris sportsman 500 awd is that mean is a 4?4
polaris 500 sportsman wiring diagram
polaris sportsman 500 awd atv
polaris sportsman 570 awd reliability
polaris sportsman awd
wiring diagram for awd on 1999 polaris sportsman
FYI.Pre owned Polaris vehicals purchased at Polaris dealers need to update Polaris. Mystro ATV General Discussion 0 07-22-2011 12:57 PM
2009 Polaris Sportsman X2 vs. 2010 Polaris Sportsman 550 X2 str8aro ATV General Discussion 12 04-21-2010 03:30 PM
