11-17-2011, 10:42 AM
Member #7031
Originally Posted by bgirard420
You have one sick custom quad
2003 Sportsman 700
Windshield-Polaris Billet gas cap-Billet Shifter
Kolpin 3way hitch-Kolpin Fuel pack-Kolpin Rear Seat
Diamond plate boot guards-radiator cover-racks
2000lb winch-Custom front bumper with enough light to turn night into day!
Custom mounted rear winch
Polaris rear grab bar
Big Gun full exhaust, soon to be dual exhaust!!
Pure Polaris Black aluminum skids
Uni air filter
COMING SOON
28" ol2's skinny wide or 28" terms skinny wide
On 14" hd3 rims
11-17-2011, 11:24 AM
Member #9763
Originally Posted by atv king
I'm pretty sure any EFI engine needs a programmer but I'm not 100% sure.
You do not need a programmer for all EFI engines. Some maybe, but they will run just fine without them. Have had exhausts on both my 700 grizz and 800 sportsman.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
01-11-2012, 10:43 AM
Member #20681
Does anybody know if the grab bar 2875550 will fit the 2011/12 500 HO ? These parts are pretty cheap on ebay. Polaris book says it fits 2005-2008 machines.
When i look up the 2008 500 HO sportsman, it shows the waterproof rear box under the fender....I'm not seeing that on the blue machine atvking has posted.
Thanks guys!
2012 Sportsman 500, Red.
01-11-2012, 11:08 AM
Member #7031
Mines a 2003 and the only thing I had to do was add the bolts to hold it on instead of using the self tapping bolts provided. As long as your machine has the two bars coming down off the rack where the grab bar mounts it should fit.
2003 Sportsman 700
Uni air filter
COMING SOON
On 14" hd3 rims
01-11-2012, 11:15 AM
Member #7031
I was looking at some pictures of a 2012 500ho and it should fit.
2003 Sportsman 700
Uni air filter
COMING SOON
On 14" hd3 rims
01-11-2012, 11:26 AM
Member #20681
Thanks for the quick reply on this. I will go ahead and order one! Too bad my machine isn't blue like yours!
01-11-2012, 11:30 AM
Member #7031
You can order a red one to match your 500ho.
2003 Sportsman 700
Uni air filter
COMING SOON
On 14" hd3 rims
01-11-2012, 11:53 AM
Member #20681
Whoa, awesome. I just found it in the 2006 pure polaris catalog. Thanks much!
01-11-2012, 01:08 PM
Member #15100
when you put exhuast on it does no good unless you change the air box and filter in some way to let more air in. and yes you should have it remaped or a programer of some kind to correct the fuel curve. The stock set up will only correct so much. So yes it could be running lean.
03 sportsman 700 running lean, atv gas cap with gauge polaris, atv grab bar craigslist 2012, atv light bar, cap on radiator for polaris, cheap atv rear grab bar, grab bar installation atv, how to instal a grab bar on quad, how to put in a predator 500 grab bar, iinstalling rear light on atv, kolpin fuel pack sr, polaris predator 500 rear grab bar, polaris rear grab bar, polaris sportsman 500 efi grab bar, polaris sportsman atv rear grab bar, polaris sportsman grab rail, polaris sportsman rear grab handle, polaris sportsman windshield, polaris trail boss 2003, predator 500 big grab bar
