Diagnostic mode for a 07 800 - Polaris ATV Forum
Old 11-21-2011, 09:16 PM
chuckinnc's Avatar
Member #16681
My service manual covers all the diagnostic codes and fuctions over several pages but never tells you how to get into it, it just says go to the diagnostic
mode.
Also my 07 800X2 (delux model) it has ADC, I don't see any to turn it on or off, is it on all the time you are in 4wd? My X2 is has (AWD, 4x2 & Turf mode)selector switch but no on/off for ADC.
07 Sportsman 800 X2 EFI
27" Mudlites on 14" ITP
everything else stock
Old 11-21-2011, 09:35 PM
SMP63's Avatar
Member #13545
Give this a try. Set parking brake, put it in neutral, hold the yellow overide button in & turn the key on but don't start it. It should show the volts in the battery, then use overide button to scroll thru. Hope this helps.
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 10-20-2014, 08:07 PM
acg_1982's Avatar
Member #47280
OK I figured the diagnosis mode out it reads 12.2 volts up to 16 volts at higher rpms. So I would assume that its charging. What would cause the voltage to run this high?
Any ideas
07 sportsman x2 800 efi how to get codes
08 sportsman 800 how to get diagonistis
2011 polaris ranger 500 crew diagnostics mode
cannot get into diagnostic mode for 2012 polaris ranger crew 500
cant enter diagnostic mode polaris ranger crew 500
how to enter diagnostic mode on ranger 500
polaris diagnostic mode
polaris ranger 800 diagnostic mode
polaris ranger diagnostic mode
polaris sportsman 800 diagnostics
polaris sportsman 800 diagnostics check how to
polaris sportsman diagnostic mode
EFI diagnostic code igica Polaris Sportsman 4 08-24-2011 02:28 AM
How accurate is the diagnostic mode? grub ATV Repair and Maintenance 2 05-26-2011 09:28 PM
diagnostic codes redbonechaser ATV Repair and Maintenance 5 01-25-2011 07:15 AM
Does a 02 Sportsman have a Diagnostic Mode? CWright ATV Repair and Maintenance 6 11-03-2010 08:42 AM
Trouble Entering Diagnostic Mode 2008 700X2 mtuser2007 ATV Repair and Maintenance 6 09-14-2010 02:15 PM
