04 sportsman 600 won't go into reverse - Polaris ATV Forum
post #1 of 16 (permalink) Old 11-22-2011, 10:32 AM Thread Starter
MOLLINS's Avatar
04 sportsman 600 won't go into reverse (I think I Found the Issue!!)
My 04 Polaris*sportsman 600*won't*go*into*reverse, it worked this am then went to back out the bike and it won't go into reverse. High low and neutral all work fine and the shifting link is not bent. There seems to be a little play though when it gos into the tranny, but engaged fine this am. Any suggestions?
MOLLINS is offline
post #2 of 16 (permalink) Old 11-22-2011, 11:57 AM
Try rocking the machine a little...sometimes if there is any pressure against it (like sitting on an incline etc.) they don't want to shift easily.
polman500 is offline
post #3 of 16 (permalink) Old 11-22-2011, 01:23 PM Thread Starter
MOLLINS's Avatar
I drove the bike around the yard a few times, tried rocking it, tried putting presure on the tranny (trying to go from N to reverse on a hill as well as facing down, level ground etc. Also tried push down on the shift lever by the tranny figuring it wasent going down far enough, but still no luck.
MOLLINS is offline
post #4 of 16 (permalink) Old 11-22-2011, 01:59 PM Thread Starter
MOLLINS's Avatar
Is there anyway to adjust the shift linkage?
MOLLINS is offline
post #5 of 16 (permalink) Old 11-22-2011, 04:14 PM
how cold is it , suppose there might be a little moisture in tranny and its froze?there is only one rod on these that runs from shift lever to tranny
Russ C is offline
post #6 of 16 (permalink) Old 11-23-2011, 09:33 AM
You might try taking the linkage loose and see if you can shift it by hand. This would eliminate the linkage as a cause.
post #7 of 16 (permalink) Old 11-23-2011, 10:46 AM Thread Starter
MOLLINS's Avatar
I took the linkage off and can shift from high low then into neutral and that's it, there seems to be a little play though when I go into neutral then to where the lever stops moving, I tried rocking the bike when shifting from neutral into reverse but still not luck. Could this be a tranny issue even though it didn't have an issue before ( or at least a warning sign?). Thanks for all the suggestions so far.
MOLLINS is offline
post #8 of 16 (permalink) Old 11-23-2011, 10:47 AM Thread Starter
MOLLINS's Avatar
I also had it out plowing today ( not fun with just forward) and tried shifting into reverse when the bike was warmed up but again still no luck.
MOLLINS is offline
post #9 of 16 (permalink) Old 11-24-2011, 06:00 AM
Mollins, have you drained/checked the trans oil? I'd drain it into a clean container to see if it has any metal particles in it and fill back up with Polaris trans oil to see it that helps.
Another thing that comes to mind is that the bell crank leaver could have loosened and slipped on the shift shaft. You might try removing it and move it up a notch or two and try it.
Will it shift all the way into park and just misses or won't go in reverse? If so, you may have internal problems with shift fork or pawl.
good luck.
post #10 of 16 (permalink) Old 11-24-2011, 06:38 AM Thread Starter
MOLLINS's Avatar
Thats a good idea (I'll take a look tonight to see), it wont go into park either, it seems once in neutral there is play till the lever stops moving. For some reason I didnt think that could be adjusted, but I just looked a t pic of it online, 1 nut and shes off! Excellent suggestion, I hope thats it!
MOLLINS is offline
NEW REVERSE OVERRIDE & REVERSE LIGHT MOD!!! no switches and working scroll feature! QuickSilver74 Polaris ATV How-Tos 103 12-08-2016 03:53 PM
NEW REVERSE OVERRIDE & REVERSE LIGHT MOD!!! no switches and working scroll feature! QuickSilver74 Polaris Sportsman 190 05-31-2016 06:50 PM
07 sportsman reverse mod sp50098 Polaris Sportsman 6 02-22-2012 10:30 AM
04 sportsman 700 no awd in reverse mroot1 Polaris Sportsman 2 02-28-2011 08:29 PM
Sportsman 4x4 Reverse? mikeirwin88 Polaris Sportsman 8 12-29-2010 12:47 PM
