1996 300 4x4 2-stroke in a box, I have plenty of questions. - Polaris ATV Forum
post #1 of 10 (permalink) Old 11-26-2011, 09:38 PM Thread Starter
DavidJoe's Avatar
I was given a 1996 300 2 stroke , someone had disassembled, there are two hose barbs sticking out of the carb, that I have no idea where they are supposed to be connected to, one is on the bottom of the carb, the other is on the left side of the carb in the center of the flow-path, both are small hose fittings. Also have plenty of compression, and spark, but I can't get it to fire up. What spark plug should I have, and what should the gap be set at? I guess that the timing cannot be moved (right?) magnet fixed in the flywheel? I have also elected to mix my fuel, and bypass the oil injection. Any help would be appreciated. Thanks , David Joe
DavidJoe is offline
post #2 of 10 (permalink) Old 11-26-2011, 10:21 PM
hsdtech's Avatar
One is a vent tube and the other is an overflow. Check your crank seals. If one is blown out/leaking it wont run. Oh and do a search here for a manual.
hsdtech is offline
post #3 of 10 (permalink) Old 11-27-2011, 05:59 AM
Bruce! is offline
post #4 of 10 (permalink) Old 11-27-2011, 06:08 AM Thread Starter
DavidJoe's Avatar
There is a line coming from the oil (injection) pump, that looks like it should hook up to one of the ports on the carb. I have a manual, just needs to be picked up, will do that Monday. Also, looking at the pic of your bike, might be a big help with the plastic and racks, when I go back together.
DavidJoe is offline
post #5 of 10 (permalink) Old 11-27-2011, 06:09 AM Thread Starter
DavidJoe's Avatar
Thanks Bruce.
DavidJoe is offline
post #6 of 10 (permalink) Old 11-27-2011, 06:13 AM Thread Starter
DavidJoe's Avatar
I am guessing that blown crank seals would be a vacuum leak? Not terribly familiar with two-stroke in practice, somewhat familiar in theory.
DavidJoe is offline
post #7 of 10 (permalink) Old 11-27-2011, 09:52 PM
hsdtech's Avatar
It actually connects to the reed cage boot on the engine side of the carb.
1997 Sportsman 400 4x4
1985 Honda 250ES BIG RED
hsdtech is offline
post #8 of 10 (permalink) Old 11-27-2011, 09:55 PM
hsdtech's Avatar
You are correct. I bought mine real cheap from a guy who said it had an electrical problem. After LOTS of troubleshooting it turned out the clutch side crank seal was blown sideways, not allowing it to run.
hsdtech is offline
post #9 of 10 (permalink) Old 11-27-2011, 10:08 PM
hsdtech's Avatar
Dave, after reading this again I think I may have told you wrong. I think one of those barbs is the fuel INLET from the gas tank. Is it vertical, pointing straight up? If it is then it should be the fuel inlet.
hsdtech is offline
post #10 of 10 (permalink) Old 11-29-2011, 09:03 AM Thread Starter
DavidJoe's Avatar
No, H, you told me correct, the two fittings I'm speaking of are about the size of fuel lines on a 2-stroke weed-eater. I found the fuel inlet.Thanks man.
DavidJoe is offline
1996 Sportsman 400 2-Stroke Overheating Jacob2k8 ATV Repair and Maintenance 6 10-29-2011 07:34 PM
1996 sportsman 400 2 stroke ljrpjr ATV Repair and Maintenance 4 09-07-2011 01:40 AM
1996 Sportsman 4x4 2-stroke cajun1 ATV New Members 1 04-12-2010 01:23 PM
1996 Xplorer 400 2-stroke problems BuckholePoet ATV Repair and Maintenance 6 01-08-2010 04:30 PM
1996 Express 400 2 stroke Droopy Drew Comedy ATV Repair and Maintenance 3 10-06-2009 08:54 AM
