12-28-2009, 06:28 PM
Member #2427
2001 500 HO pulls to the left
i was wondering if perhaps the hubs werent disengaging? Is there fluid somewhere that might need changed and where would it be at?
12-28-2009, 07:09 PM
Member #2326
Yes there is Fluid in the front differential. It should be changed regularly, as it sees a lot of friction small metal particles build up. Use only Polaris fluid in the front diff. If you can, let it drain overnight. On the bottom will be a drain plug and the fill is upper left(i think) on the diff case.
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
YouTube Channel: www.youtube.com/user/tinkerman01
12-30-2009, 08:50 PM
Member #2073
There is also fluid in the hubs on your model. Requires Polaris demand drive hub fluid. There is an allen head plug on each hub, fill it with the hole in the 4 or 8 o'clock position.
12-30-2009, 08:57 PM
Member #1644
make sure all 4 of your tires are at the same pressure, and check and see if you have a bent tie rod end.
01-03-2010, 09:03 PM
Member #2427
if the fluid is low what symptoms could it cause?
01-14-2010, 01:59 PM
Member #993
Disengage 4X4 and drive backwards 20-30 yards. Could be hub not disengaging. Visually check brake pads to ensure they're not frozen on the disk.
01-14-2010, 06:16 PM
Member #2198
Have a 2000 sportsman 500 and you need to change that hub fluid in the front wheel hubs. Take it for a good run so it is warm then drain it right away and let it drip for a while. refill with the proper fluid only to the right level and you will be good to go.
06 polaris sportsman 500 pulls to the left while riding, 2000 sportsman 500 hub metal, 2001 polaris 500 pulls to the left, 2001 polaris atv pulls, 2001 polaris pulling to the left, 2001 polaris sportsman 500 ho pulls to the right, 2001 sportsman 500 ho hub wont disengage, 2001 sportsman 500 pulling right when 4 wheel drive is on, 2001 sportsman hub disengage, 2007 polaris sportsman 500 pulls to left, front right tire wont work in four wheel drive on a 2001 sportsman 500, my polaris 400 sportsman pulls to the right, polaris 500 atv pulls to left, polaris 500 ho front hubs, polaris 500 ho wheel alighment, polaris atv 2001 front alignment, polaris atv front wheel alignment, polaris atv pulls left, polaris sportsman front wont pull, polaris sportsman pulling to left
