Old 12-31-2009, 06:48 PM
magnum's Avatar
Member #2513
2005 Magnum 330 AWD ignition switch; 4x4 wire; manual
Hello-
I just purchased a used 2005 magnum 330 AWD Polaris ATV. A couple of issues with it.
The first is the wiring harness connection to the ignition switch. The male end has at lease one short and does not provide a continual connection to the lights and starter. I am having difficulty finding any part reference or numbers to the harness or wire bundle that plugs into the ignition. The ignition seems fine. Any suggestions on diagrams and location of the electrical parts?
The second (known) issue is the wire that connects to the four wheel drive at the front gear box. The wire is dangling-any diagrams on that connection point?
The final question is location of parts and owners manual. Service manual would be nice too. Also, where is the serial number located?
Thanks in advance-
magnum
Old 01-01-2010, 02:03 PM
Old 01-02-2010, 07:25 PM
magnum's Avatar
Member #2513
Quick update-fixed the harness issue. Prongs on female side were bent and not connecting properly. Prior owner rigged wiring-seems OK now.
I am still wondering if anyone has a diagram or picture of the 4x4 connection to the front end. Not sure where it connects. I found another wire pulled loose-not sure what it goes to yet.
Also looking for online source for manual. I have purchased tractor manuals and unless you know the source well, the quality is marginal. Free online PDF would be great, but unlikely.
Ran into another issue with shifter. Figured out the spring on the brake pedal. Reattached and it shifted to H and P after that. Worked for a while-now grinding and slamming in gear while running. Shifts fine with engine not running. Removed the drive belt-3211077 part number and hope to find a replacement tomorrow. I have NAPA cross reference. The belt is pretty stiff and a few outside corners are worn off. I'd say this is the original belt. Not sure how often they are normally changed.
2005 polaris 330 magnum
2005 polaris 330 magnum wiring diagram
2005 polaris awd parts and wiring
2005 polaris mag 330 carb diagram
2005 polaris magnum 330
2005 polaris magnum 330 manual
2005 polaris magnum 330 rear axle diagram
2005 polaris magnum 330 service manual
2005 polaris magnum 330 wiring diagram
free polaris wiring diagrams
polaris 330 awd
polaris 330 magnum manual
polaris 330 magnum service manual
