Old 01-02-2012, 07:02 PM
phbush2003's Avatar
Member #10704
my 4x4 dont work
have power to the hubs just not sure what to replace in the hub.i thiught about starting with the armeture plate and new magnites. any ideas would help
Old 01-04-2012, 12:26 AM
Xploder's Avatar
Member #15971
Be help to us to tell us what year you have?, remove the hub's, with the key on and in gear place a armature plate up to the coil and see how much magnetism it has, if it's real hard to turn there good, turn easy or nothing at all you might have a open wire to hub, check under yout front cover theres 2 connectors with 2 wires each that go to the hubs each has a brown and grey wire, unplug it and check for 25 ohms, also test for 12v to hubs.
Make sure the hilliard ramps up eaily rollers should move freely inside cage.
2002 awd dont work in reverse streetbob ATV Repair and Maintenance 5 11-29-2011 05:51 AM
you dont need this!!! cooltoyz ATV Repair and Maintenance 3 08-25-2011 09:17 AM
brakes work great than they dont. then work agian thepopeis1 ATV Brakes & Suspension 1 08-07-2011 04:07 PM
05 500 HO headlights dont work camaross ATV General Discussion 1 06-24-2010 07:22 PM
2005 sportsman 700efi 4x4 dont work Mitch18118 ATV Repair and Maintenance 2 05-06-2010 07:20 AM
