Old 01-04-2012, 05:35 AM
Thunderdually's Avatar
Member #6444
thumb throttle
Any one have or know where i can get a used thumb throttle for a 06 Polaris sportsman 450. I just need the thumb lever it’s self. Seems Polaris either needs money or they are just money hungry not sure which. They won’t sell just the lever you have to buy the whole switch assembly for over $160.00 It’s a shame they have to screw the people who buy their products for $ 5 worth of plastic.
2006 Sportsman 450 Stock
Wifes
Old 01-04-2012, 06:40 AM
stmar's Avatar
Member #17361
Look on Ebay, they have all kinds of options so you may be able to find something that will work. Would one of those aftermarket extenders work or the twist grip mod?
Old 01-04-2012, 09:53 AM
AKStew's Avatar
Member #5212
We have an ATV salvage yard nearby where I am usually able to find what I need. You might check around your area to see if one exists there.
You might also try craigslist to see if somone might be parting out a machine that has the same throttle assembly as yours. I believe the only difference for several years was the type of 2x4/AWD switch that was in the assembly.
Sometimes a non-dealer repair shop will have old parts laying around. You might get lucky with one of them...and they might know where to get used parts as well.
stmar's thumb extender idea sounds pretty good too if you have enough of the old one left to attach it to.
Stew
Old 01-04-2012, 11:25 AM
Its the stupid electronics that you dont need that cost this much. But you can do this.
You can buy from the dealer or online this OEM# 2010335. Its entire throttle assembly, from a 2x4 trail boss. But it should only be like $30 still. Then you just take the lever off of the new throttle assembly and put in on your current assembly housing. I think its like one philips screw is all, underneath the the lid of the housing.
Did it all the time for customers when I worked at the dealer. Worked great. It should work for everything 2005 and newer that is a "utility" line-up and not an XP. It may work for older machines, and XP's, just never tried it.
But it should work well for you, unless something has changed since I left the shop, but I doubt it has.
Old 01-04-2012, 11:41 AM
Member #6444
Stew
Thank you for your reply. We don't have an ATV scrap yard any where close But i will try some of the dealers and see if they have a used one.
I can't use any kind of extender because the thumb lever has a plastic shaft that broke off inside the switch box.
Thank you for the information. $30 dollars is still a lot of money for a small plastic part but it's a lot better then $160 that's for sure. I'll check out that part.
I'm going to keep a spare with me just incase one breaks again. it's a bitch being stuck out in the woods.. LOL
Wifes
Old 01-06-2012, 08:55 AM
Member #6444
Well I fixed the problem traded it in on a new Can Am runs great now. J/K I Epoxied the stem back to the lever part with Plastic Weld then as the stem is hollow I filled it with quick steel putty epoxy to give it more strength so far it’s holding..
Wifes
Old 01-06-2012, 10:44 AM
AKStew's Avatar
Member #5212
Well, that's one way to fix it! I bet the epoxy works. That stuff is amazing if it can get a hold onto something.
Good luck,
Stew
Old 01-06-2012, 03:45 PM
shui5612's Avatar
Member #19703
i feel your pain...
on my seadoo theres a small TINY little propeller, with 4 blades and holds on a 1"long 1 mm thick metal "rod".
those blades break off eventually... either from getting on a trailer or from the speed....
seadoo only offers the entire speed sensor with the propellor... AKA 250$ for a 5$ prop... its JUST a piece of plastic....
luckily i have found some for sale on ebay...just the little prop but for 25-35$ plus shipping... major ripoff..
id look around ebay... maybe find a thumb throttle that someone makes for quads....
another thing would be... find a good neighboor with a quad like yours... sneak out at night (assuming the atv is outside, if its stored inside, flood their garage so they put the atv outside for the night and steal the thumb throttle and put your broken one back on his...
LMAO just kidding..
im not sure if these thumb throttles are used for other powersports other than the atv...
anyone have any ideas? like some snowmobile .. so that maybe the parts are for sale through them..
also, look for the part at atv dealers or people who repair quads they might have one laying around from an old quad...
2007 800EFI X2 Deluxe
-polaris 2500# winch
-tool grips
-VIP air windshield
-safety flag (polaris)
-Glacier II plow system
-front hitch
-1700KM
2010 850 XP EPS
- 2500# polaris winch
- VIP air windshield
-498KM
2005 polaris 500 sportsman thumb mechanism for throttle assembly
2005 polaris sportman 90 throttle lever
2005 polaris sportsman 500 thumb mechanism for throttle assembly
2012 polaris sportsman has play in the throttle
ebay safety throttle polaris parts
polaris 450 sportsman throttle lever
polaris 500 ho throttle spring
polaris 500 sportsman thumb throttle
polaris 550 throttle lever
polaris 800 sportsman thumb throttle breaking
polaris atv broken front spring 9
polaris predator 500 throttle diagram
polaris predator 500 thumb throttle will they fit any year
polaris sportsman throttle
polaris thumb lever
throttle spring polaris 500
thumb extenders polaris
thumb throttle 2005 sportsman 700
what are the points for inside the throttle assembly of a 2005 polaris sportsman 500?
thumb throttle broke 850 xp waynev Polaris XP 23 03-01-2012 03:40 PM
Thumb Throttle Problems smore79 Polaris Sportsman 5 07-22-2011 04:29 PM
Replace thumb throttle jesscb ATV New Members 9 03-09-2011 02:41 PM
Twist throttle vs. thumb throttle? rsmith0801 Polaris Predator 5 03-22-2010 05:11 PM
Thumb Throttle VS Twist Grip Throttle Billster1955 Around The Garage 12 01-27-2010 07:54 PM
