Old 01-05-2012, 06:34 AM
DwightCobra's Avatar
Member #21452
94 400L 4x4 lower ball joint removal help
I'm restoring a 94 400L 4x4 and im having one heck of a time removing the lower ball joint. I assume its the original ball joint, and i dont want to mess up the aluminum strut in the process. Any suggestions?I have heated the surrounding area, a couple of days of penetration oil, but its not moving.
Old 01-05-2012, 10:28 AM
Old 01-05-2012, 04:43 PM
87CYCLONE's Avatar
Member #21964
If the threads are still there and good you can cut out a short piece of pipe and slide it over the bolt. Obviously the pipe has to be bigger around than the ball joint. Then put a heavy duty washer over the bolt and pipe and thread the nut on. This will act as a puller to pull the ball joint up out of the strut and into the pipe. It works about 7 out of 10 times. Them joints can be pretty stubborn!
1987 250-X Cyclone
1987 250 Trail Boss 4x4
Old 01-05-2012, 05:07 PM
gmiller0737's Avatar
Member #1628
I agree I used a large socket & a washer.
Old 01-06-2012, 06:11 AM
Member #21452
thanks for the suggestions , ill post how it goes
Old 01-06-2012, 07:59 AM
lrge pair of vise grips, clamp them onto stud tightly, get a torch and heat bottom of strut around joint, get it pretty hot, hit vice grips with hammer and it will come out, if you have a large deep socket that will fit the new joint you can tap it back in while still hot.
94 polaris sport lower balljoint removal
atv ball joint vice
ball-joint-remover pipes
how to remove a lower ball joint on polaris
how to take a ball joint off a polaris sportsman 800
lower atv balljoint
polaris 400
polaris 400 ball joint removal
polaris atv 4x4 balljoint parts
polaris ball joint puller
polaris ball joint removal
polaris lower ball joint replacement
polaris lower ball removal
polaris sportsman ball joint maintenance
polaris sportsman ball joint removal
polarislower ball joint removal
remove lower ball joint front strut polaris
remove lower ball joint on polaris atv
remove polaris ball joints
05 sportsman front lower ball joint removal mv7 ATV Brakes & Suspension 3 12-25-2011 05:03 AM
2011 550 lower ball joint wobble Brickman550 ATV New Members 3 09-13-2011 08:33 AM
2002 Sportsman 500, Lower Ball Joint? sprysa ATV Repair and Maintenance 3 04-04-2011 02:41 AM
Bad ball joint or not? ...plus A-Arm removal tip. scottdeet ATV Repair and Maintenance 11 03-22-2011 06:00 AM
Lower Ball Joint for '88 Trail Boss HighPlainsDrifter ATV Repair and Maintenance 2 11-10-2009 04:59 PM
