01-05-2012, 09:19 AM
Member #21986
500 efi wont shift
my 500 efi sportsman with ebs won t shift while running i have to shut the bike down and shift then re start.i took the belt of and the bike shifts running no problem?whats up
01-05-2012, 10:28 AM
01-06-2012, 08:06 AM
ebs washers bad in primary clutch,? is it creeping?, how fast is it idling?
01-06-2012, 08:29 AM
Member #9763
Easiest fix and issue I have run into is high idle. If you are idling too high then you will not be able to shift.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
01-08-2012, 01:28 PM
Member #10569
like stated it could be idle speed, the one way bearing could be bad or a misalignment of the primary and secondary clutches. If the clutches are not aligned it will not shift until you cut it off. Check for broken motor mounts, this will throw the alignment off.
2012 polaris 550 won't shift while running, atv will not shift while running, atv wont shift when running, ebs washers in primary clutch, my 02 polaris sportsman 500 h.o. is shifting hars and creeping what could be the issue?, my atv wont shift with the clutch in, polaris 400 atv wont shuft, polaris 700 efi wont shift while idleing, polaris 700 sportsman wont shift into hi, polaris 700 wont shift, polaris 850 wont shift when running, polaris atv wont shift, polaris ebs washers sportsman, polaris sportsman wont shift, polaris sportsman wont shift while running, sportsman 500 wont shift while running, sportsman 800 efi wont shift while running
