01-05-2012, 08:56 PM
Member #19170
2011 800 efi uni air filter worth it???
Hey guys im SURE this has been brought up but, was just going to ask if its worth the 30$ to put a uni air filter in my 800 popo. Will I actually get some HP gains? Thanks as always for any input
2011 Sportsman 800 efi:
Polaris HD 2500 winch
Polaris front and rear bumper
14" SS212 Rims
27" GBC Spartacus tires
3 headlight mod
2005 phoenix 200:
01-06-2012, 12:50 AM
Member #1958
Your HP gains will be zip but for $30 you'd have a filter that can be washed reoiled and reused dozens of times rather than a $15 stock filter that you use once and throw away to be replaced with another $15 stock filter.
01-06-2012, 01:59 AM
Member #20904
good filters
Unis are good filters as I have one on my 500 sportsman and i will agree with the previous response, after you buy a couple of paper filters the Uni will be paid for. I am happy with mine because I can clean it after every ride.
01-06-2012, 07:36 AM
Member #9763
No on the horsepower gains, but yes to getting the filter. Filter is reusable so will pay for itself.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
01-06-2012, 07:44 AM
Member #17251
yes i have the uni on mine. no horsepower gain, but its great, you can wash, and re oil. definatly worth it
2011 Sportsman 800 efi- 2 inch RDC lift, 28in backs, itp ss212 black wheels, polaris front and rear bumpers, polaris 2500 winch, rear rack extender, uni filter, bazooka tube up front, polaris hand guards. Gorillas axles, mods to come: snorkel
01-06-2012, 08:00 AM
Member #1031
I have tried them all K&N, Uni etc and non of them seem to work any better then the stock one on a stock machine. The Uni is a great filter if you don't mind the hassel and mess of cleaning it all the time, and the cleaner and oil is not cheap in the long run. I would not run a K&N on a lawn mower let in way to much dirt. I have just gone back to stock.
Mine 2009 Sportsman 850 XP Camo, Bighorn 2.0 tires, rear cago box with back rest, steel rear rack extender, Oury Grips, Polaris grip warmers, thumb warmer, Polaris fender bag, Promark 3,000 XTR winch, polaris Handguards, extreme front brush guard with PIAA lights, custom front rack Rotopax fuel pack carrier.
Hers 2009 Sportsman 400HO Camo, Warn 1,500, winch, Polaris Handguards.
Grandson 2001 E-Ton Rascal 50
Ours 2009 Fuzion FZ302 35ft 5th wheel Touring Edition toy hauler.:usa
01-06-2012, 08:05 AM
Member #9763
Problem with the stock filter is if you get water in your airbox out on the trail, the filter is trash and you are stuck without a filter. If you have a k&n or Uni and it gets wet, you can just shake it out and/or put it under the exhaust of another machine to dry it out and get back on the trail.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
01-06-2012, 09:17 AM
Member #1031
I use a filterware pre filter over my stock filter and it is somewhat water repelant, but since I don't use my machine like a boat or a submarine I don't worry about the water issue to much.
06 polaris 800 air filter, 2011 polaris 800 air filter, 2011 polaris sportsman uni, 2011 polaris sportsman uni filter, a k&n or uni filter for sportsman 300, air filter on 2011 sportsman 800, atv uni air filter hp gain, how tight uni filter sportsman 300, polaris 800 efi, air filter, works, polaris 800 uni air filter, polaris sportsman 800 efi k&n intake forum, polaris uni air filter, sportsman 800 air filter, sportsman 800 efi air filter, uni air filter for 07 polaris sp 500 x2 efi, uni air filter in efi atv, uni filter for atv with efi, uni filters forums atv, when to replace air filter 2011 800 efi, when you should replace your polaris sportsman 800 pre filter
