Old 01-06-2012, 08:56 AM
super820's Avatar
Member #7232
2010 800 sportsman fan switch
My fan quit working i hit connector it starts
Such a tight spot to wire direct anyone else have problem?
Old 01-06-2012, 02:36 PM
AKStew's Avatar
Member #5212
Sounds like you found the problem in the connector. Unfortunately, sometimes it seems as if we have to tear the whole thing apart to get to a simple fix.
Good luck,
Stew
Old 01-07-2012, 10:16 AM
super820's Avatar
Member #7232
Good luck,
Stew
Ya found it but having a hard time fixing lol
get it to work then drive it for a bit and stops then overheats
whats the best way to wire the fan to ignition?
leave it run all the time?
Old 01-07-2012, 01:47 PM
bgirard420's Avatar
Member #11494
A few people run this one with good results.
ATV Mud Tires ATV parts, ATV tires, Quadovator ATV Accessories
2010 Sportsman 500 H.O.
Old 01-07-2012, 07:05 PM
AKStew's Avatar
Member #5212
Good luck,
Stew
If you unhook the fan wire from the temperature sensor it will run all the time (provided the broken wire isn't the power source). I would fix the real problem or you will eventually burn the fan motor out.
STew
08 sportsman fan wiring
800 sportsman fan problems
aftermarket polaris fan switch
fan switch for 2010 sportsman 800
fan wiring sportsman 500
poarlis 800 motor fan
polaris 800 fan problems
polaris fan switch
polaris sportsman 500 aftermarket fan switch
polaris sportsman 800 fan problems
polaris sportsman 800 fan switch
wire a fan switch sportsman 500
wire switch polaris sportsman 500
WTB Ignition Switch Nut 01 Sportsman 500 HO trohrer ATV Parts for Sale 3 01-07-2011 11:08 AM
kill switch 94 sportsman ratherbflyn Polaris Sportsman 8 11-27-2010 11:50 AM
96 sportsman thermal fan switch banditboy21 ATV Repair and Maintenance 0 10-23-2010 07:19 PM
Sportsman 400 4x4 switch keninox ATV Performance Modifications 1 10-10-2010 08:19 PM
sportsman 500 switch problem 1blueberry1 ATV Repair and Maintenance 4 08-27-2010 04:51 AM
