Old 01-07-2012, 01:47 PM
DwightCobra's Avatar
Member #21452
94 400l 4x4 ball joint update
thanks for all your suggestions. The Joint was too worn to use the "grease gun" method, and heat alone with the vice grips wouldn't budge the dam thing. So i went to the local Mexican Home depot and made a getto puller and heated the bejesus out of it. And finally it popped. Thanks for all the help. I have to be a little careful banging on the thing here since parts have to come from the states and if i break something, sob,sob. Anyway i got it out, thanks again.
Regards,
DwightCobra
94 400L 4x4 lower ball joint removal help DwightCobra Polaris Sportsman 5 01-06-2012 07:59 AM
Bad ball joint or not? ...plus A-Arm removal tip. scottdeet ATV Repair and Maintenance 11 03-22-2011 06:00 AM
ball joint pro4 ATV Repair and Maintenance 2 01-02-2011 05:13 AM
Rear tire ball joint CV joint? rich in co Polaris Sportsman 3 08-22-2010 01:55 PM
ball joint replacement matt19 Polaris Predator 2 06-24-2010 06:37 AM
