Old 01-07-2012, 04:52 PM
hunter1980's Avatar
Member #22055
fuel tank issues sportsman 800
I just bought a 2005 sportsman 800efi test drove it everything ok. Went riding with a buddy today shut off twice took the fuel cap off when it was running gas came shooting out tank is pressureizing and bubbling in the tank. need help please it only has 98hrs 700 miles
Old 01-07-2012, 09:15 PM
Old 01-07-2012, 09:25 PM
shui5612's Avatar
Member #19703
wait what?
you mean the fuel cam shooting out of the gas tank?
the only thing i would think it would be is the pressure relief valve...
plus there could have been a some fuel on the cap or between the cap and tank that leaked out..
not reall understanding what your problem is... did it like fly out? how much fuel was in the tank?
as for the fuel bubling , do you mean it had bubles coming up or it just had bubles on the inside?
2007 800EFI X2 Deluxe
-polaris 2500# winch
-tool grips
-VIP air windshield
-safety flag (polaris)
-Glacier II plow system
-front hitch
-1700KM
2010 850 XP EPS
- 2500# polaris winch
- VIP air windshield
-498KM
Old 01-08-2012, 04:13 AM
bgirard420's Avatar
Member #11494
Make sure the tank vent isn't plugged as it sounds like you are vapor-locking. The tank should not be pressurized because it is an open system so-to-speak. My gas bubbles with the machine idling from the vibration not from boiling. If that is your concern use a meat thermometer and check fuel temp. Just some thoughts...
2010 Sportsman 500 H.O.
Old 01-08-2012, 04:20 AM
hunter1980's Avatar
Member #22055
what I am asking is there a vent hose for the tank that could be clogged up.what i dont understand if the engine is running take fuel cap off the engine dies
Old 01-08-2012, 03:47 PM
yes vent hose is under plastic in front of fuel cap, might also put more insulation on bopttom of tank, the heat will boil the gas, Read AK STEWS, Fixed post .
09 sportsman 800 gas
2005 polaris sportsman 800 gas boils
2011 sportsman 800 fuel tank
atv fuel tank pressure
gas boiling in a polaris 800
gas tank for sportsman 800 2005
how big is the fuel tank on a polaris sportsman 800
polarig gas tank vent
polaris 2005 atv sportman 90 gas tank
polaris 800 fuel boiling
polaris 800 fuel issues
polaris 800 fuel tank pressure
polaris 90 gas tank
polaris x2 gas tank vent
sportsman 800 boiling gas
video how to check fuel valve on 99 polaris sportsman 500
what fuel to i put in my sportsman 800
can't get my fuel tank back in my sportsman 500 k9scooter ATV Repair and Maintenance 0 09-29-2011 08:07 AM
Sportsman Fuel Tank Wear Wheelerdude ATV New Members 2 08-21-2011 06:53 PM
08 800 sportsman pressure in fuel tank markiedog Polaris Sportsman 7 02-28-2011 10:29 AM
what is the best to put in a gas tank when fuel is 3 yrs old to clean it plastic tank 1986polaristrailboss ATV General Discussion 11 09-07-2010 07:57 PM
re installing fuel tank in '99 sportsman 500 bluedge8 ATV Repair and Maintenance 2 05-25-2010 01:35 AM
