If it is starting with the pull chord, and not the starter either the starter is bad, or the battery is on its way out and cant crank hard enough. At least that would be my guess. You may be able to test the battery or starter if you have access to a system diagnostic tool... or at least making sure the battery is creating the right voltage.
2002 Polaris Sportsman 400 4x4
