Old 01-07-2012, 09:49 PM
solid_crimson's Avatar
Member #12721
reasons for adjusting springs?
Im just curious about why everyone adjusts their springs in the rear. My 500ho is really soft in the rear. Im wondering if this would help and if others do this what is the main reason they do want to adjust them? Thanks guys!
Old 01-08-2012, 03:33 AM
Member #12721
Anyone?
Old 01-08-2012, 04:07 AM
bgirard420's Avatar
Member #11494
When you say soft, are you bottoming out?? What model do you have and what are you trying to accomplish by changing the tension??
Many people will increase the tension in relation to load. Examples: If you are heavy and carrying a dead dear on the back or towing a heavy trailer then the added weight may bottom out your suspesion in the rear. Add a plow and winch and the front end sags under the load. Because of this, the front tends to be more of an issue than the rear. There are many limitations to just increasing tension so some opt to add stiffer (HD) springs, particularly in the front.
2010 Sportsman 500 H.O.
Old 01-08-2012, 04:08 AM
lost cause's Avatar
Member #9763
You adjust them to either stiffen or soften your springs depending on your weight/riding style.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 01-08-2012, 11:46 AM
Member #12721
My problem is in the rear. I think im bottoming out. I weigh about 220the and when I ride for a bit then get off my quad I notice that it doesn't spring back up all the way. Compared to what it use to. Its an inch off from where it was. ... I have a 2011 polaris sportsman 500ho. With about 70 hours on it.
Old 01-08-2012, 11:58 AM
bgirard420's Avatar
Member #11494
I hear ya now. Get a good pair of channel locks and go to town, can't hurt to see how you like it with them turned up. If that doesn't quite get you what you're looking for then you may want to look into HD springs. Mine doesn't return all the way up when I get off either, sits down a inch or 2 but I can't say I've ever bottomed out.
Old 01-08-2012, 12:05 PM
Member #12721
Sounds like what im experiencing is normal then. But what would you consider bottoming out.
Old 01-08-2012, 01:20 PM
bgirard420's Avatar
Member #11494
I call bottoming out when the springs under load reach the maximum compression and end up transferring energy to the frame. A "thud" so-to-speak. I've done it once with my front end carrying a load beyond the recommended amount and once going over whoops. I've never had it happen in the rears. Do you feel the rear sags? HD's should help it stand up a little taller if this is the case.
Old 01-08-2012, 02:15 PM
Member #12721
I feel that it does sag a little. But it is fine when I ride it. It is just when I get off then I notice when I pull up on the rear it will lift up 1 maybe 2 inches. I am just concerned with it not springing itself back up all the way. Does this sound odd or am I being paranoid. I just want to make sure that I'm taking care of my quad.
Old 01-08-2012, 03:50 PM
bgirard420's Avatar
Member #11494
I could be wrong but I believe that there should be a certain amount of compression of the spring from the mere weight of the machine alone. Mine moves just like yours, about an inch or two. I think it has something to do with down travel. A soft spring with some preload will extend your suspension downward when you are going over ruts, bumps and jumps which adds stability by keeping "rubber on the road."
I just installed richochet ultimate protection and I had an issue in the rear because of this. I am actually in the process or writing a post to help others who may do the same as me but I digress. Briefly, I put the rear a arm guards on with the quad on the ground and suspension drooping an inch under the weight of the machine. When I went out to ride, the down travel was actually causing the guard to take out my rear brake caliper and leaving me without brakes!! I ended up trimming it and now it's fine but it took me a few minutes to figure out what was going on. It was a little scary
adjust polaris rear shock
adjusting polaris sportsman shocks
adjusting rear springs on 2012 polaris atv
adjusting spring load on polaris atv
adjusting spring tension polaris suspension
adjusting tension on polaris atv
adjusting the front springs on a polaris sportsman
adjusting the rear springs tension 2010 polaris 400 ho
adjusting the spring tension on a polaris atv
ajusting spring suspension seat post
anyones polaris sportsman sag way to low when towing
do you need to adujt front shocks when adjusting the backs of polaris sportsman
heavy rear springs for polaris sportsman sag when towing
how to adjust the rear spring on a quad
polaris atv
polaris rear springs 500
reviews on 2012 polaris 500ho good
spring adjust polaris
whay adjust quad front springs
whay polaris sporstsman really sags when towing
Adjusting shocks SledRacer112 ATV Brakes & Suspension 11 09-01-2011 11:02 AM
Adjusting clutch king15428 Polaris Predator 3 08-20-2011 05:43 AM
Adjusting rear springs, Any adverse effects? kool_500HO ATV Brakes & Suspension 4 05-02-2011 10:07 AM
Adjusting clutch polaristrailboss1991 ATV Repair and Maintenance 1 04-24-2011 05:21 PM
Adjusting suspention dodgeram3500 ATV Brakes & Suspension 11 03-17-2010 08:34 AM
