Old 01-08-2012, 08:29 AM
stmar's Avatar
Member #17361
'08 400 HO Oil Capacity?
My owner's manual says that the oil capacity is 2 qts. Is this correct for the 455cc engine? The reason I ask is that I changed the oil and filter, added the full 2 qts. and the dip stick barely registers after running it a bit. I don't want to overfill but do not want to run it low either.
Old 01-08-2012, 02:08 PM
1of7627's Avatar
Member #4155
Yes, two quarts is the factory figure, but I always adjust to the dipstick being careful to check the oil after fully warmed up and after running the engine a minute to stabilize the level in the tank. (My service manual says to run it 20-30 seconds before checking.) I always change the oil only by draining the tank and changing the filter. (I don't drain the sump or pull the oil hoses from the tank.) I never have to add much to satisfy the dipstick.
I don't feel there's much danger in over filling (as long as you don't fill the tank completely and not leave any room for expansion and normal oil flow) and would rather have a bit more in the tank than too little.
Just a note on filters, I tried to use an oversize (longer) filter but found there wasn't enough room for it. (The frame is in the way.) I also made a small heat shield that I fasten to the filter with a stainless hose clamp that fits between the filter and the exhaust pipe. I have no proof it helps, but I feel better as the pipe is only a half inch or so from the filter. MarkC
MarkC - Spokane, WA USA
Old 01-11-2012, 09:35 AM
stmar's Avatar
Member #17361
I very carefully added oil to get to correct level per dipstick. I even started it a few times and checked it trying to make sure I covered all bases. It took another 3/4 of a quart (for a total of 2.75qts.) to get it to where the dipstick showed normal!!! Like I said above, the manual says 2 qts. Is it possible the '08 455cc engine takes more?
Old 01-11-2012, 04:16 PM
JoeG's Avatar
Member #4228
My 09 400HO takes 2.75 qts. also.
Old 01-11-2012, 04:26 PM
1of7627's Avatar
Member #4155
I checked the owners manuals for all three years of this model (08-10) and they all have the same oil capacities and change instructions. Many other Polaris models do too, and the oil change kit Polaris sells for these models contains two quarts of oil. Though I've never measured it, I'm quite sure I've never added 3/4 of a quart after filling the tanks on my two machines. All I can say is that if you're checking the oil per the instructions (ie: running engine first, screwing cap all the way in, etc.), then you shouldn't be in any danger of either over or under filling. - MarkC
Old 01-11-2012, 06:37 PM
RichH's Avatar
Member #19920
make sure you are screwing the dipstick back in all the way when you check the level (warmed up)/ when I changed my 2 08 400 ho's, I drained the tank/ then drained the block (not much comes out)/ then (with the switch in the off position) I used the recoil pull start ( slowly about 4 pulls) and actually got a little bit more out of the tank. I refilled with 2 qts./ used the pull start again to fill the oil filter/ started and warmed up and topped off. total oil right at 2.4 qts. I check them before every ride (never low at all/ never discolored) Amsoil 0-40 Formula 4 stroke.
2011 Sportsman 550 x2-
Guru Cobra front
L&R Mid-Windshield
2008 Sportsman 400 HO - Wife's Ride (red)
2008 Sportsman 400 HO - buddy's buy'n mine (Camo)
Old 01-12-2012, 06:13 AM
stmar's Avatar
Member #17361
When I changed the oil and filter I opened all plugs and let it drain for a long time so I feel like I got most of the old oil out of the machine, although I did not pull the starter. At least now I know I am not crazy and that other people put in more than the recommended 2 qts. to fill to spec. It would be interesting to hear from a dealer tech and as to if the 455cc takes more oil. Thanks for all the input.
Old 01-14-2012, 02:49 AM
Miker's Avatar
Member #5376
Fyi - From your owners manual page 76, at the top
Always change the oil and filter at the intervals outlined in the Periodic
Maintenance Chart beginning on page 68. To change the oil properly,
always drain the oil tank and change the oil filter.
NOTE: If oil contamination (water, mud, metal shavings) is suspected in the
engine sump, the sump should also be drained. Draining the engine
sump will require additional oil not contained in the oil change kit. The
total oil capacity of the engine sump and oil tank combined is 2.25 qts.
(2.1 liters).
2011 polaris 400 ho oil requiremrnts
2012 polaris sportsman 400 fluid specs
changed oil in polaris 2012 550 and oil level is low with 2 quarts
how many quarts of oil goes in a polaris 800 sportsman 2010
how much oil does a polaris 400 ho
oil capacity 2012 polaris sportsman 400 ho
oil capacity for a 2010 polaris sportsman 400
oil capacity of sportsman 400 h.o.
oil change 2008 400 polaris sportsman
oil level on 08 400
oil sump polaris sportsman 400
oilchange 08 sportsman 400 ho
old drain for 2011 sportsman 400 ho
polairs 400 oil change
polaris 400 oil capacity
polaris oil capacity
polaris sportsman 400 ho 09 oil how many quarts
polaris sportsman 400 oil capacity
sportsman 400 oil change
Fuel tank capacity? Dryrider ATV General Discussion 1 10-14-2011 06:07 PM
oil capacity? beardog ATV Repair and Maintenance 11 12-15-2010 01:54 PM
oil capacity starter moter JEFFrey ATV Repair and Maintenance 4 04-19-2010 02:23 PM
Sportsman 800 pulling capacity ? Grunthunter Polaris Sportsman 11 02-13-2010 03:02 PM
Oil capacity of Outlaw 500? Gary Benson ATV General Discussion 4 08-01-2009 04:40 AM
