Old 01-08-2012, 11:41 AM
atles618's Avatar
Member #16222
Unhappy 2004.5 sportsman clutch
I am having a problem with the primary cluch not opening up at idle and the atv stalls out . I pulled of clutch and found a lot of cracks on outer flange can i get it welded and machined or do i have to replace it or is there something else that i am missing.
Old 01-08-2012, 01:24 PM
klevister's Avatar
Member #10569
Go ahead and replace the clutch. Look on ebay and see if you can find the clutch off a 2005 or newer. These have a smaller one way bearing on it, so it actually gives it a lower starting point on take off. You can really tell a difference with the clutch swap, i have done it on my 04.5 500 HO.
Old 01-08-2012, 01:44 PM
Kevcules's Avatar
Member #14887
Clutches are very expensive but if yours is worn too bad , then replace it with a new one IMO. My 01 has a few small 1/4" cracks also. I decided to try to save it by drilling a 1mm hole at the end of the crack , just like a windshield. If the crack gets any larger then its going to be replaced with a new one. The dealer wants $550 for the primary assembly without weights and shoulder bolts, but they only want $50 more for a complete clutch "kit". This includes a new primary assembly , a new secondary assembly , and a new belt. Unless you can find a good price on a good condition used clutch then buy new and it should last a long time.
Good Luck
Kevin
04 sportsman clutch kit
2004.5 polaris 700
2004.5 polaris sportsman 500
2004.5 polaris sportsman 500 clutch
2004.5 polaris sportsman 500 clutch problems
2004.5 polaris sportsman 700
2004.5 sportsman 500 good or bad?
2004.5p0laice
clutch sportsman 90
polaris atv 2004.5
polaris sportsman 90 clutch replacement
2004 Sportsman 700 driven clutch Thor2911 ATV Repair and Maintenance 2 05-22-2011 02:44 AM
wanted polaris 2004 sportsman 700 primary sec. clutch jaggs ATV Parts for Sale 1 07-27-2010 08:38 PM
does a 2004 predator have a stsrter clutch? jdq21 Polaris Predator 1 01-19-2010 09:23 AM
2004 Sportsman 700 EFI Clutch Problem Ben2009 ATV Repair and Maintenance 4 12-09-2009 10:57 AM
2004.5 Sportsman 700 EFI Big tire kit/clutch kit help... Flipmode22 ATV Wheels & Tires 8 11-23-2009 09:09 PM
