Old 01-08-2012, 01:03 PM
bjohn10's Avatar
Member #22092
2004 Sportsman 500 overheating???
I recently purchased a used 2004 Sportsman 500 HO with 1,700 miles. The machine mechanically sounds solid however, when I run the machine for 15 to 20 minutes at a time, antifreeze in the overflow pushes out. The fan turns on and runs pretty much the entire time. When I first purchased the machine, I noticed the fluid level in the overflow was low. I opened the radiator cap and the fluid was right at the top. I filled the overflow to the middle of min/max. I rode the machine for the first time afterward and as discribed above, the fluid pushed out the overflow cap. No overheating light or any indicator on the machine comes on. Any help would greatly be appreciated. Also, the radiator is clean front and back with no leaks. No leaks in the hoses either.
Old 01-08-2012, 03:49 PM
fl1tontj's Avatar
Member #18836
I'm dealing with the same prob, let me know ifyou come up with anything. I even took the t stat out and it still runs hot.
Old 01-08-2012, 05:14 PM
Old 01-09-2012, 04:26 AM
remove radiator cap, let machine run till fan comes on , will burrp air out of system , if its pushing fluid out of radiator may have blown head gasket
Old 01-09-2012, 07:05 AM
4getful2's Avatar
Member #1234
Take the radiator cap and have it tested.
Old 01-09-2012, 05:13 PM
bjohn10's Avatar
Member #22092
Thanks very much for the feedback. I will test the cap, made replace it if, and run the machine until the fan kicks in. Hopefully this solves the issue. It does not smoke or smell of antifreeze other than the residual from it pushing out the top of the overflow. I will test it this weekend and post the results.
Old 01-11-2012, 04:20 AM
smokeybone's Avatar
Member #16170
Keep me posted..my 03 600 just did the same thing yesterday!!! Hell, I'm not even sure my radiator has a cap.
Old 01-11-2012, 07:05 AM
bjohn10's Avatar
Member #22092
I will keep you posted. The bad thing about a early 2004 Sportsman is they hid the raditator cap under the front storage rack without an access door in the front plastic. I have to remove both just to turn the cap off.
Old 01-11-2012, 07:30 AM
smokeybone's Avatar
Member #16170
Talking
Thanks for the info! I guess I do have a cap! lol I'm thinking mine is the thermostat, but my fans are not comming on??
Old 01-14-2012, 05:26 PM
bjohn10's Avatar
Member #22092
Well, it turned out to be a bad radiator cap.... The spring would move up and down but the rubber gasket on the bottom was shot. I replace the cap and ran the machine for two hours on local trails near my home with zero issues. The fluid would fill the overflow to the max line, then the fan would kick on and the level would drop. Thanks to everyone for the assistance and for responding. I truely appreciate the feedback...
Brad-
Tags
sportsman 500 overheating
01 sportsman overheating with new sensor
04 polaris sportsman coolant
04 sportsman 500 fan not working
2004 polaris sportsman 500 overheating
2004 polaris sportsman 500 overheating problem
2004 sportsman 500 cooling fan
2004 sportsman 500 overheating
2004 sportsman 500 overheatting
fan good but wont come on 04 polaris 500 sportsman
my polaris 500 sportsman is over heating
overheat sportsman
overheating polaris 500
overheating problems in a polaris sportsman 500
polaris 500 coolant leak after fan kicked on
polaris 500 spits antifreeze
polaris sportman 500 overheats
polaris sportsman 500 pushing antifreeze out bottle
radiator cap for polaris sportsman
what does brown above radiater cap on 04 polaris 500 connect to?
overheating sportsman 700 EFI bigboy73 ATV Repair and Maintenance 5 11-03-2011 08:25 AM
Sportsman 800 Overheating, fan won't come on levi'sford Polaris Sportsman 14 10-09-2011 04:34 PM
98 Sportsman 500 Overheating rmckenna Polaris Sportsman 6 09-02-2011 07:12 PM
2004 Sportsman 400 Overheating Amused2Deth ATV Repair and Maintenance 4 11-28-2010 05:29 PM
2004 sportsman 700 overheating issue midnite_99 Polaris Sportsman 16 04-01-2010 02:58 PM
