Old 01-10-2012, 10:09 AM
ppolaris1010's Avatar
Member #15104
04 600 sportsman head gasket
does anyone know if the 04's had head gasket issues or head bolts stretching.mine has been losing coolant at first it was the water pump so i replaced the seals but it still is losing coolant with no leaks and the oil looks kind of milky but not bad.im going to replace the headgasket but should i do the bolts as well and should i have to do the base gasket to.
Old 01-11-2012, 04:17 AM
smokeybone's Avatar
Member #16170
I've got an 03, and its blowing coolant out of the resivoir. COuld it be the thermostat? I'm pretty sure she's getting too hot, but the fans arent kicking on. Any suggestions? Sorry My oils fine. ( i just changed it, and went for a ride..thats how i found the overflow)
Old 01-11-2012, 10:09 AM
RZRBound's Avatar
Member #14038
I have a 03 aswell. Either blew a head gasket or the inner (oil) seal on the water pump went south. Took a look at the oil and looks like a dark chocolate milk shake....
Mine has always blown coolant out of the resevior if I filled the bottle to high when the motor was cold. You have any oil mixing with the coolant or visa versa? Mine has been mixing oil with the coolant for the past year and also has been steadily losing coolant with no trace of where it went before this and now I have found some in the oil (Thats why I'm leaning toward the oil seal on water pump) but still not positive. As far as bad gaskets or stretching bolts, no I havent heard anything about that.
Old 01-11-2012, 11:49 AM
Member #15104
yours needs a fan switch mine did the same thing last year.do a search on here for it somewhere there is a napa part number for the switch polaris one is like 70 bucks napa is way cheaper.mine has been getting coolant in the oil and i replaced the water pump seal and it still does it so now im doing the head gasket
Old 01-14-2012, 05:20 AM
smokeybone's Avatar
Member #16170
My fan is not kicking on...Could this be my problem?? Can u unhook the switch and it will run constant? or what?
Old 01-14-2012, 08:00 AM
if you unplug the sensor, lower right corner of radiator with key on, fan should run, if not fan or sensor bad, hoo 12 volts to fan at plug in, if fan runs, sensor bad , can get new one at auto parts stor but will have to splice old plug ont new sensor, Wells #sw- 526Echlin #fs-147
Old 01-14-2012, 08:03 AM
p-polaris 10 10, sounds like head gasket and yes I would replace base gasket cause bolts go all the way through, do you have a manual? it will tell you torque and tightening sequence
400 polaris sportsman head gasket, how to tell
600 sportsman oil leak
atv head gasket sealant
atv head gasket sealer
blow head gasket on atv
head gasket repair on a polaris sportsman
how hard is it to do a head gasket on a polaris atv
how to change head gasket on 03 polaris sportsman
how to change head gasket on 600 sportsman
how to repair a blown head gasket on polaris atv
how to tell if thermostat on polaris sportsman is bad
my polaris 90 oil looks like chicolate milk
oil in atv look like chocolate milk
polaris magnum thermostat seal gasket
polaris sportsman 600 head torque
polaris sportsman 600 thermostat
replace head gasket on polaris sportsman
replacing engine gaskets on sportsman
sportsman 600 head gasket
would the fan still kick in if the head gasket has blown on a polaris
think i have a blown head gasket on my 97 400 sport Yo4eva ATV General Discussion 2 06-05-2011 05:06 PM
Replacing my head gasket sr975j ATV Repair and Maintenance 2 03-31-2011 09:26 PM
330 Magnum head gasket kecamcmaga Polaris Magnum 3 01-10-2011 07:35 PM
2002 tb blown head gasket rickybobby ATV Repair and Maintenance 2 11-15-2010 06:19 AM
Blown head gasket??? Jeff Wright Polaris Sportsman 5 09-04-2010 07:32 AM
