Old 01-10-2012, 05:20 PM
08sport500's Avatar
Member #18814
08 sportsman 500 efi wont idle
my bike will start up, but as soon as it does i have to feather the throttle or it dies. runs fine, but it just started doing this on the weekend since i put a jerry can of gas in it. would water in the gas cause this?
Old 01-15-2012, 04:38 PM
08sport500's Avatar
Member #18814
i syphoned as much gas out as i could, and refueled with new gas and its still doing it... nobody has any ideas?
Old 01-15-2012, 04:53 PM
jandj's Avatar
Member #12027
Try adjusting the throttle freeplay, it should be 1/6"-1/8" of play. The adjustment is down a little on the handlebars, just pull the boot up and the ajuster is right there.
  • 08 500 EFI
  • LandR rear box
  • 2500#Mile Marker
  • AME heated grips
  • UNI filter
  • Stock 26"PXT wheels
  • 3 headlight mod
  • 08 420Rancher ES
  • 2500# Mile Marker
  • ATV TECH rear bag
  • AME heated grips
  • UNI filter
  • 25"Power grips
Old 01-15-2012, 05:01 PM
POLARIS13's Avatar
Member #20347
mine did this just recently....it would start up and i would have to feather the throtle multiple times until the 4th or 5th time and it MIGHT start...i took it to my dealer, and they gave me a new plug and wires....its on the right side by the footwell. My cousin had to replace it too....but i just got it...ill let you know if it fixes the problem
Cost me like 45 bucks.
Old 01-15-2012, 05:08 PM
08sport500's Avatar
Member #18814
Thanks I'm gonna go try the throttly play right now. Let me know how the plug wires work
Old 01-16-2012, 12:19 PM
08sport500's Avatar
Member #18814
The throttle freeplay was exactly what it was. Thanks for the help guys!
Old 01-17-2012, 08:08 AM
POLARIS13's Avatar
Member #20347
i replaced the plug wires (t-bat sensor) its the one that hooks into the airbox intake tube...so if you take off the top cover on the air box, its under that. and it geels like i have soo much more power and its running better! but im glad your throtle control worked!
Old 01-17-2012, 09:42 AM
08sport500's Avatar
Member #18814
glad to know it worked ot for ya!
Old 05-09-2012, 11:47 PM
krmerback's Avatar
Member #26142
sportsman 500 efi won't idle
I followed the adjustment instructions given and solved the problem. Thank you very much
2012 polaris sportsman 500 wont idle
500efi sprotsman starts but dies
idle on polaris 500
my efi wont idle
my polaris efi atv won't idle
my polaris sportsman 500 efi will not idle
my polaris sportsman 500 will run but not idal
polaris 500 efi running rich at idle
polaris sporstma 500 efi wont idle
polaris sportsman 500 efi erratic idle
polaris sportsman 500 efi rough idle
polaris sportsman 500 efi rough idle#gsc.tab
polaris sportsman dies when takeoff
polaris sportsman wont idle
sportsman 500 efi wont run
sportsman efi rough idle
why does my polaris efi not idle
2006 Sportsman 500 EFI wont idle buffaloman ATV Repair and Maintenance 7 09-25-2011 06:23 AM
500 EFI wont idle RY86 ATV Repair and Maintenance 1 08-14-2011 07:37 PM
08 500 wont idle crazyredneckak ATV Repair and Maintenance 5 05-13-2011 04:13 PM
350 sportsman 1993 wont idle any ideas bigman223 Site Issues & Suggestions 2 07-23-2010 06:19 PM
Sportsman 500 wont idle Aggiemike Polaris Sportsman 5 04-10-2010 04:00 PM
