Old 01-11-2012, 12:41 PM
Fubar's Avatar
Member #21425
Using a lot of oil
Have a 2012 850xp. Total hours is around 14 now but I keep check of the oil level and it seems to be using enough that I've added 1/2 qt so far. I know a new engine will use a little oil but this seems a bit much. Maybe because there is only 2 qts total it seems like the level drops quickly.. Don't know. Anyone have any ideas?
2006 Polaris Sportsman 500 HO Camo
2012 Polaris Sportsman 850 XP EPS
2012 Polaris RZR 900 XP EPS (special edition)VooDoo
Old 01-11-2012, 01:16 PM
cdaniels5758's Avatar
Member #12782
Sounds like a lot. My 550 doesn't use a drop. Never has.
Craig
2010 550XP EPS
Old 01-11-2012, 01:26 PM
4getful2's Avatar
Member #1234
You should talk to your dealer
Old 01-11-2012, 01:27 PM
Fubar's Avatar
Member #21425
I don't see it coming out the exhaust either. Not on the garage floor... Don't know where it's going.
Maybe it wasn't full when I got it from the dealer.... I hope
Old 01-11-2012, 06:15 PM
TLWolfe63's Avatar
Member #22174
Maybe it's in your air box???
Old 01-11-2012, 06:49 PM
xjugs's Avatar
Member #19572
Send a message via Yahoo to xjugs
I would check the airbox since you havent seen any signs of leaking.Just pull your seat off and remove the airbox lid.Myself and many others would be curious to know your results as 2012 parts have been suggested as a fix for some of our machines.
Old 01-12-2012, 04:45 AM
Fubar's Avatar
Member #21425
I'll do that this weekend.... and let you know.
Old 01-12-2012, 05:04 AM
Yea maybe Polaris came up with a self oiling K&N filter system?
Old 01-12-2012, 04:19 PM
Donovan514's Avatar
Member #21246
I'm sooo curious as to if the oil is in the air box. I'm with the guy who said Polaris didn't add enough oil from the get-go.
Old 01-12-2012, 04:20 PM
Donovan514's Avatar
Member #21246
Do it now! It takes 2 minutes
900 xp using oil
polaris 900 xp using oil
polaris atv
polaris sportsman 800 using alot of oil
polaris sportsman 850 xp crankshaft issues
