Old 01-13-2012, 04:46 PM
Ksmith's Avatar
Member #22268
06 sportsman 800 overheat issue
I recently bought an 06 sportsman 800 with 800 mi on it. I've been plowing with it and the other day it overheated on me. I have checked the water pump impeller, removed the fan and cleaned the radiator and checked the thermostat. I can run it for about a half hour before it over heats. When the hot light flashes the fan is is not running. If I shut it off and turn the key on the fan will run. It seams when the machine warms up good the fan quits working. Also my battery won't hold a charge I have tO jump it to start it. Could this be the problem? I read that if the temp sensor is unPluged the fan will default to run constantly but I'm guessing the battery must be fully charged for it to run? Thanks for any help you guys can give. Lots of good info on here.
Old 01-13-2012, 06:08 PM
Old 01-14-2012, 05:59 AM
Ksmith's Avatar
Member #22268
Old 01-14-2012, 06:15 AM
Donovan514's Avatar
Member #21246
Message some people on here. Look for moderators and see if they know some good tech's that can help you out.
Old 01-14-2012, 07:49 AM
needs a good battery for evry thing to work right, if battery is bad, thats where I would start, they are expensive for the twins, $120-130, I get the AGM ones fom o'reilly's, seem to work well. yes if you unplug sensor, lower right corner of radiator with key on , fan should come on, can get sensor from auto store, wont have the right plug in on it ,you willhave to splice the old one onto new sensor,Wells #sw-526, Napa -Echlin# FS-147
Old 01-14-2012, 08:07 AM
Ksmith's Avatar
Member #22268
Thanks for your help. The temp sensor for mine is on the head near the thermostat I believe. If there is one on the radiator I couldn't find it. Should still work the same though correct?
07 polaris sportman 800 temperature sensor
2006 polaris sportsman 800 overheat
2006 sportsman 800 battery wont hold charge
2006 sportsman 800 overheat sensor
2012 sportsman 800 overheating
atv overheats when plowing
battery for 800 polaris atv
heating sensor on a polaris 800
my sportsman 800 is overheating
polaris psortsman 800 overheating
polaris sportsman 800 overheating
polaris temperature sensor atv 800
removing radiator on 06 sportsman 800
sportsman wont hold a charge
temp for a polaris sportsman 800
wells sw526-
where is temp sensor on 06 sportsman 800
why is the sportsman 800 battery so expensive
04 400 overheat musselmark Polaris Sportsman 3 11-06-2011 06:46 PM
2011 sportsman 500 overheat millinski Polaris Sportsman 6 09-22-2011 06:40 AM
2006 Trail Boss 330 overheat/fan issue BillInEscondido ATV Repair and Maintenance 4 09-21-2011 03:59 PM
05 700 Overheat SurveyDan ATV Repair and Maintenance 1 04-18-2011 02:17 PM
500 Overheat demingrickjames Polaris Sportsman 7 08-06-2009 07:13 AM
