Old 01-14-2012, 06:29 AM
proatv's Avatar
Member #19453
Help! 2006 Polaris Sportsman 700 EFI foul plugs
My plugs keep going foul! Can anyone tell me how to fix this? Whats wrong with it?? thanks in advance
2006 Polaris Sportsman 700 Twin EFI
with ProMark Offroad Outback Series 3500 LB. winch
Old 01-14-2012, 07:46 AM
are you letting it sit and idle alot?or starting it, lettin it idle then shuttin it off again? the efi models start in a rich modethat doesnt shut off till engine warms up and computer shuts it off, when you start it cold, let it run for a minute or two then go ride it till its warm, dont let it sit and idle long or idle a little then shut it off.
Old 01-14-2012, 08:48 AM
proatv's Avatar
Member #19453
Yes, i know about that and i do not do that!
I changed them both yesterday and it ran fine and then today it happend again!
Old 01-14-2012, 06:15 PM
needs -re flashed at dealer, running too rich
Old 01-15-2012, 04:46 AM
proatv's Avatar
Member #19453
thanks much any idea how much this is?
Old 03-25-2012, 12:12 PM
proatv's Avatar
Member #19453
could it be the oxygen sensor? and can i replace it myself?????????????????thankks
Old 03-25-2012, 05:54 PM
AKStew's Avatar
Member #5212
There is no O2 sensor. The t-bap sensor may be bad (unlikely) or the throttle position sensor could be bad or out of adjustment.
Stew
2006 polaris sportsman 700
2006 sportsman 90 spark plug
2012 polaris sportsman fouling plugs
atv fouling plugs
best spark plugs for polaris sportsman 700 efi
finding the o2 sensors on a polaris sportsman 700
fouling plugs on atv
plug atv 700
plug fouling out polaris 500
plug on polaris sportsman efi
polaris atv 700 sportsman changing spark plugs
polaris atv non fouling plugs
polaris sportsman 700 spark plugs
polaris sportsman 700 stock spark plugs
polaris sportsman fouled sparkplugs
polars 700 efi running rich
spark plugs2006 sportsman 700
sportsman 2006 efi fouls plug
sportsman 700 twin efi running rich
where are the spark plugs on a 700 polaris 2006
Spark plugs for a '04 Sportsman 700 Twin dsu96 ATV Repair and Maintenance 9 04-15-2012 06:00 AM
2006 Polaris Sportsman 800 LE Badger 13 ATVs For Sale 3 07-20-2011 08:15 AM
2006 polaris Sportsman 450 bldefelice36 Polaris Sportsman 1 04-26-2011 03:21 AM
polaris scrambler fouling out plugs Falken400 Polaris Scrambler 4 11-02-2010 10:25 AM
Fill Plugs and Drain Plugs bama13 ATV Repair and Maintenance 0 04-14-2010 01:24 PM
