01-14-2012, 06:34 PM
Member #21790
Polaris "Lock & Ride" Windshields
Did any of you buy the Polaris "Lock and Ride" clamp on windshield for their X2 or Touring? If so, did you find it awkward to install with those clamps having to move all the wiring and cables out of the way? I wasn't impressed with their quick install design.
I installed it but I think it's easier to take on and off by just removing the two pivot bolts on the arms. Otherwise you end up messing with all the wiring and cables. I also have the winch control on the left handlebar which added another wire.
The overall quality is great but when they claim 15 second install they must have forgot the effort it takes to cut all the plastic cable ties, stretch out the wires and cables, fumble with the adjustable clamps, lock it on and then reposition the wires, cables and reinstall the new plastic cable ties and trim them.
I get frustrated real quick.
2011 Sportsman 850 X2 LE Sage Green
01-14-2012, 08:19 PM
Member #20894
Polaris Windshield
I installed one of the Polaris windshields on a 2011 Touring 850 recently.
You are right, it was awkward the first time I installed it and it took longer to install it than the brochures claimed it would. I was concerned about damaging the wires the first time.
After it had been on a week or two, I removed it as I was making some other changes and when I put it back on the quad, it was much easier. I guess I knew I was not going to hurt the wiring.
Overall, I am pleased with the quality of the windshield and the mounting system seems sturdy and I don't anticipate any problems.
I would recommend it if asked.
01-14-2012, 11:32 PM
Member #18732
I have an 850 x2 and have the short shield. I removed all the zip ties and retied the after putting the shield on. This way it somewhat removes easier. Just something to try.
2011 850 X2:
Glacier III Plow
Polaris 2500 Winch
Polaris Rear View Mirrors
Polaris Hand Guards
Polaris Black Short Windshield
Symtech 4 Ch. Heated Grips
Promark ATV Tow Kit.
01-15-2012, 06:51 AM
Member #14149
haha I put all the bumpers and brush gards and boxes on my dads 850 and I think the hardest thing to put on was the windshield it made me fell like a dumb ass
01-15-2012, 08:30 AM
Member #16252
I have the low windshield on my X2, If I wanted to take it off, I would have to cut all the zip ties off of the handlebars. I agree its not really a 15 second install, especially with my heated grips, winch and power pivot control wiring.
1998 Xplorer 300-Stock
01-15-2012, 05:07 PM
Member #21790
Yeah, I agree. Now if I want to remove it, I just take it off with the two bolts on the arms, maybe a minute or so involved. I'm happy!!!
It just seems like they should have designed it with a fixed clamp on the bars and had the "lever clamps' nearer the windshield where they were easier to access. Just my 2 cents.
I have the 850 X2 with the Lock and Ride enclosed box on the front and I really like the way it installs and removes. It makes getting to the battery and coolant refill point a breeze. Just thought they dropped the ball with the windshield mounts.
01-16-2012, 07:26 PM
Member #19920
mounts are solid, but longer install than they say/ first ride with it yesterday/ it was real cold and snowing back in the hills/ I didn't get cold/ blocks that cold air very nicely. only in the way if turning very sharp.
2011 Sportsman 550 x2-
Guru Cobra front
L&R Mid-Windshield
2008 Sportsman 400 HO - Wife's Ride (red)
2008 Sportsman 400 HO - buddy's buy'n mine (Camo)
01-19-2012, 11:47 AM
Member #21218
I have installed the foctory windshield on my X2,I leave the arms on the bars and use wing nuts on the bolts to on and off the windshield.At the very least the height of the shield is usually the same.
01-20-2012, 04:21 PM
Member #21790
Update ---> I went to the Home Depot and found 2 of the plastic knobs they use on push lawnmower handles to fold them when transporting. These knobs have SAE 5/16's threads. I also picked up 2 -- 5/16 x 1.25" bolts. I removed the metric bolts with the nylock nuts on the arms. I replaced the nylock metrics stuff with the plastic knobs and SAE bolts
Now I can install and remove the windshield at the arms without any tools. The knobs are very close to the headlight pod but dont hit it, you have to insert the 1.25 bolts and start the knob letting it pull the bolt through. It's easy enough and I don't need a wrench to take the windshield on and off.
01-20-2012, 07:51 PM
Member #19920
good idea/ future project
Guru Cobra front
L&R Mid-Windshield
how to install lock and ride windshield on polaris sportsman 500, how to install polaris lock and ride windshield, install polaris lock and ride windshield, is the polaris atv low windshield any good, lock & ride winshield clamps, lock and ride windshield sportsman 500, polaris atv lock & ride windshield, polaris atv quick and lock, polaris atv windshields, polaris lock and ride clamps, polaris lock and ride mounts, polaris lock and ride windsheild, polaris lock and ride windsheild install, polaris lock and ride windshield, polaris lock and ride windshield black, polaris lock and ride windshield removal, polaris lock and windshield installation, polaris windshield clamps, removing a lock and ride windshield, removing lock and ride windshield
