Old 01-15-2012, 02:40 PM
POLARIS13's Avatar
Member #20347
sportsman back basket/rack
has anybody built, or bought a basket that mounts behind the wheeler!?
IF SO...lets see what ya got.
thanks!
Old 01-16-2012, 04:50 AM
PASportsman's Avatar
Member #18930
Komodo ATVMFC ATV Multi-Fit Carrier - Walmart.comgot one of these for Christmas but haven't installed it yet. I figured it would be ok for a cooler on the short rides and a gas can on the longer ones!
2004 Sportsman 700, Warn winch, Polaris plow, Swamp Fox tires
Old 01-17-2012, 02:34 AM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
I have a full-width droprack on mine. Adds a lot of cargo room but be careful of the weight you put in it especially on steep inclines. Adds 15 inches to length and weighs 40 pounds.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
Old 01-17-2012, 03:26 AM
res2cue's Avatar
Member #15153
Here mine on the wife's machine!(daughter messing around on it) Anyways this one is adjustable up and down. This is in the low position I ended up putting it up in the higher position.
found it here,
Guide Gear Atv Rear Drop Basket, Atv, Guide Gear, Guide Gear Rear Atv Drop Basket at Sportsman's Guide
I did have to do some fab work to the part that sits over the rack/seat area. If you look close I cut off a section of the expanded metal where it would have gone over the seat and welded some square tubing to reinforce the the expended metal.
If I did not do this, I would have to remove the rack to remove the seat.
Old 01-17-2012, 04:49 AM
I would not be climbing any steep hills with that extra weight behind the rear axles. That system will make the ATV very light in the front.
Old 01-17-2012, 07:30 AM
pjmartin's Avatar
Member #5074
I have a cargobox full of tools, spares etc. on the front rack and I carry a 2.5hp Merc in front of the cargo box above the bumper so it balances out. Without the cargobox and outboard, I agree with you especially since you're usually in low gear and my 500HO is hard to throttle smoothly in low. Bit skittish.
Rear drop rack
2000lb winch
No mods
2001 polaris sportsman 400 front rack
2001 polaris sportsman 400 rear rack seat
2001 polaris sportsman rear rack dimensions
2011 polaris sportsman front rack specs
2011 sportsman rear rack
2012 polaris sportsman 400 back rack
2012 polaris sportsman 400 rear rack cargo
2012 sportsman 500 basket
2012 sportsman 500 rack basket
atv metal rack basket
basket for 2012 polaris sportsman 400
basket rack for hard thread
drop basket for polaris 550
gas can holder for atv rear
polaris rear rack size
polaris sportsman gas can
polaris sportsman rear bumper drop rack
rack basket for 2012 polaris
sportsman front rack width
New front basket jde512 ATV Visual & Body Modifications 1 11-10-2011 07:35 AM
2009 Sportsman 500 HO Metal Rack Basket bradj63 2009 1 12-20-2010 03:39 PM
ranger back rack thereheis ATV General Discussion 0 11-08-2010 11:06 AM
Rack Extension Project (Back Porch) Tumbleweed ATV Visual & Body Modifications 11 05-20-2010 05:47 AM
Polaris/Rath Sportsman 850 XP –Back to Back Wins! dascrow Polaris ATV News 3 08-07-2009 05:56 PM
