Old 01-15-2012, 03:42 PM
ronbell2u's Avatar
Member #22337
Hard to make tight turns - Rear Axle Solid?
When I am trying to turn going slow it feels as if the rear axle is locked and trying to make me go straight. I get a little push on the front end if you know what I am trying to say. I have checked the alignment and tire pressures and that is good. While this may be a good setup for the mud and trails it tears up my back yard and I can't pull my utility trailer with it.
Does the rear wheels/axle allow for tight turns or is it like a solid axle?
Thanks in advance for any support.
1999 Sportsman 500
Old 01-15-2012, 03:52 PM
halfa12pk's Avatar
Member #11938
Send a message via AIM to halfa12pk
the 99 sportsman has a solid drive. no slip at all
Old 01-15-2012, 03:56 PM
Old 01-15-2012, 11:51 PM
bosnjo's Avatar
Member #18373
Yes, mine is the same and no Turf Mode on it. The Turf Mode is something IŽd realy like to have as I ride a lot on paved surface and locked rear differential doesn't help at all.
2011 Sportsman Touring 850 EPS
------------- Portugal --------------
- Wind deflectors
- Rear motorcycle box
- Front Brush Guard
- Car tires
- GPS Garmin Dakota 20
- Road legal
Old 01-19-2012, 05:07 PM
ronbell2u's Avatar
Member #22337
Thanks for the replies as that was what I thought too.
1999 Sportsman 500
atv turns hard
solid differential dor polaris sportsman
rear axle help!!! Sweenman 88 Polaris Predator 11 12-23-2011 04:39 AM
exactly how much wider will this offset make my XP-3+3 front and 5+3 rear crimson850 ATV Wheels & Tires 1 10-01-2011 04:27 AM
Rear bumper install 2010 500 a tight space and fat fingers ohioheader ATV Visual & Body Modifications 11 04-09-2011 01:59 AM
Rear Prop Shaft Turns -- Rear Wheels do not fz1oakville ATV General Discussion 2 02-25-2011 12:32 PM
sound in rear end when turning tight? jeepguy Polaris Sportsman 2 04-29-2010 03:14 PM
