Old 01-15-2012, 04:57 PM
Rjbeck77's Avatar
Member #22254
Idle RPM
What RPM should I expect in park and in high?
Old 01-15-2012, 04:59 PM
Rjbeck77's Avatar
Member #22254
4wheel drive reverse
Ook my bik out or the first time today. I tried 4 wheel drive the only time the display shows its engaged in reverse I when I hold down the override button. Is this typical? Is there anyway to have it engaged without holding the override button?
Old 01-15-2012, 05:35 PM
jordaman17's Avatar
Member #13240
what machine do you own?
Old 01-15-2012, 05:46 PM
Rjbeck77's Avatar
Member #22254
2007 500 ho efi
Old 01-15-2012, 06:08 PM
jordaman17's Avatar
Member #13240
1200 to 1400 rpm
Old 01-15-2012, 06:09 PM
Rjbeck77's Avatar
Member #22254
Thank you!!
at what rpm should a pilaris 500 h.o.
how many rpm should atv idle
how many rpms should a polaris 450
idle rpm for polaris sportsman 500
idle rpm forl polaris sportsman 500
idle speed 450 po0laris sportsman
polaris atv
polaris atv idle speed
polaris sportsman 500 idle rpm
polaris sportsman idle rpm
polaris sportsman idle speed
polaris sportsman rpms in park
sportman 500 efi idle rpm
what engine rpms should a polaris 500 sportsman idle at
what is low idle rpm for 2012 polaris sportsman 500 ho
what is the idle speed set at on a 2012 polaris sportsman 500?
what is the normal rpm at idle for a 2012 polaris sportsman 500
what rpm shoul sportsman 500 idle
500 efi will not idle allenpace ATV Repair and Maintenance 1 11-06-2011 07:58 PM
What RPM should be Idle Parker88 ATV Repair and Maintenance 2 04-12-2011 06:34 PM
How to set idle? ferg_29 Polaris Outlaw 1 06-03-2010 04:44 PM
Will not idle??? ryoung ATV General Discussion 4 02-21-2010 05:09 AM
idle too low or not? pafree ATV Repair and Maintenance 5 02-16-2010 01:24 AM
