01-15-2012, 05:02 PM
Member #22254
4x4 reverse
Took bike out or the first time today. I tried 4 wheel drive the only time the display shows its engaged in reverse I when I hold down the override button. Is this typical? Is there anyway to have it engaged without holding the override button?
01-15-2012, 05:20 PM
Member #21790
What model? That doesn't sound right.
Well on my 850 X2 the "R" flashes when I put it in reverse but it does show up. I thought I reviewed the owners manual thoroughly. My manual indicates that a symbol "---" means its not completely in gear but doesn't mention the flashing that I remember. I didn't notice what it did when I hit the RPM limit over ride button.
I'll try to make time to go back through the manual again. I'll also try the over ride button in reverse to see what the display does.
Maybe some one else will chime in.
2011 Sportsman 850 X2 LE Sage Green
01-15-2012, 05:30 PM
Member #13240
4x4 only works in reverse when the over ride is pushed on certain models
01-15-2012, 05:48 PM
Member #22254
2007 500 HO with EFI Sportsman
01-15-2012, 05:55 PM
Member #10305
The 500's are setup so u have to push the override in reverse for AWD, I know there is a way to get around the override button but I can't remember how
I am here: http://maps.google.com/maps?ll=43.476431,-105.347781
01-15-2012, 06:05 PM
Member #13240
01-16-2012, 02:55 AM
Member #22071
Dealer told me on my 11 800 EFI that you had to push the override button for the AWD to work in reverse, he said it was the ONLY WAY the AWD would work in reverse
2011 Sportsman 800 EFI
1996 Magnum 425 4x4
ITP 589 MT's
01-16-2012, 11:25 AM
Member #20681
+1 on the kit. I have ordered it but have not installed it yet.
2012 Sportsman 500, Red.
2008 polaris sportsman 500 ho reverse button isnt working, do you have 4x4 in reverse polaris sportsman, polaris sportsman 500ho no 4wd in reverse, polaris sportsman 90 only works in reverse, sportsman 4x4 only in reverse, super atv 2 lift sportsman review, when in reverse does 4x4 work
