01-16-2012, 10:04 AM
Member #21501
Few Question on Lifting my 800
Iam looking to lift my 2010 sportsman 800. Here is a link to a small lift i found.
Polaris Sportsman Lift Kit 500 600 700 800: 1999-2011 | eBay
Is this what i would need? How hard is it to install a lift like this? Are there any issues after a lift like this? Should i be looking for something better than this? Sorry for all the questions new to the site just ready to do some mods to my atv. Thanks in advance for any help
Operation Iraqi Freedom Veteran
Operation Enduring Freedom Veteran[/B]
2010 Polaris 800
3 Light Mod/Hid's/K@N Air Filter/FMF Efi Power Programmer/Outlaw Clucth Kit/Reverse OverRide Eliminator/14'' SS 108/27'' Gream Reaper's/Polaris-Front/Rear-Rack's/Bumpers/3000lb Viper Winch/Hand Gaurds
01-16-2012, 11:14 AM
Member #13240
yes that's all it is. not hard to do. no issue's with mine. i have one like that.
01-16-2012, 03:56 PM
Member #12019
Not that hard to do???? Could a 60 year old man do it by himself??? Will it cause any undue wear and tear on the machine? I only use mine for plowing snow and riding to ice fish, which is normally a 25 mile round trip.
Something like this looks like it would really help me with plowing, as I would assume that raising the front end 2" on my 2011 Sportsman 800efi, would also raise the blade 2" too. I purchased the Glacier III plow and it works fine so far. However the wear bar SUCKS. I plan to do the same as my other machine and head to Alro Steel and pick up a piece 1/2"x4"x60" and replace the original, which after only a couple times used, it almost worn to the blade.
01-17-2012, 12:50 AM
Member #21501
Thanks went ahead and ordered it yesterday. Should look good with a nice set of wheels and tires.
2010 Polaris 800
01-17-2012, 01:07 AM
Member #11177
I had considered doing the lift...but I have no interest in upgrading axles and such....I know some people say they have put it on with no problem, but I'm in that group that would have excessive wear on axles and would end up with some broken parts to replace...
Mine - 2007 Sportsman 800 - 27" Mudlites on SS rims, HID's, 3 headlight mod w/ relay, 2500lb winch, 4 gal rotopax, PowerMadd hand guards
Wife's - 2010 Polaris Sportsman 500 HO - HID's, 3 headlight mod w/relay and 2500lb winch, WES rear seat & kimpex foot pegs, 4 gal rotopax
01-17-2012, 01:40 AM
Member #21501
Do I or Should i upgraed axles after a 2in lift? I plan on 14in rims and maybe some 28'' silverbacks. So next step for me is a clucth kit. Wasnt plannin on upgradin the axles just yet.
2010 Polaris 800
01-25-2012, 07:20 AM
Member #2163
don't upgrade your axles until you have to and when you do I recommend superatvs rhino brand axles cheaper than gorillas and are fine if your not a heavy throttle rider
1996 sportsman 400 4x4
aaen performan pipe
cluth kit
power reeds
.20 over wiseco piston
27" Gorrilla Silver backs
12"itp alluminum wheels
super atv 2" lift
venom 3000# winch with synth rope
Snorkel
01-25-2012, 07:29 AM
Member #9763
I have never seen that kit installed before, but I can tell you that if it does lift the front the full 2" then there is fabrication involved. You have to grind the front struts around where the axle goes into the hub. When you change the angle of the axles the boot rubs on the strut and wears through the boot. And as far as The rears usually last fine, but the fronts will break. Especially if you are running those silverbacks like you intend. And do not waist your time or money on the rhino brand axles. My stock front axles lasted 5 mins. after installing the lift, and my rhino brand lasted about 16 hours. Get gorilla or turner.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
01-25-2012, 09:49 AM
Member #17251
agreed, i am still running my stock axles and have been in some pretty deep stuff. just be careful with the throttle. If you do upgrade, go with the gorillas!!!
2011 Sportsman 800 efi- 2 inch RDC lift, 28in backs, itp ss212 black wheels, polaris front and rear bumpers, polaris 2500 winch, rear rack extender, uni filter, bazooka tube up front, polaris hand guards. Gorillas axles, mods to come: snorkel
2012 polaris sportsman 800 efi lift kit, 2012 polaris sportsman 800 lift kit, 2012 sportsman 800 rhino axle, 3 inch lift on 2012 sportsman 800, 3 inch lift on sportsman 800 will it break rhino axles, best lift kit for 2012 sportsman 800, cheapest 2 inch lift kit for a polaris 800 sportsmen, efi programmer polaris 800, extreme 3 inch lift polaris sportsman 800, how do you install a lift kit for 2012 polaris 800s, how to install lift on 2012 sportman 800, lift kit 3 inch for polaris sportsman 800, lifting atv questions, polaris 800 sportsman lift pics, polaris sportsman 800 4 lift kit?, polaris sportsman lift kit 500 600 700 800: 1999-2011, should i lift my atv, should i lift my sportsman 800, sportsman 800 4 inch lift, sportsman 800 lift kit
