01-16-2012, 08:55 PM
Member #17647
Does warranty cover the battery?
I bought my Sportsman 800 in August(5 months ago to the day). If the temp is below freezing, I have to use a jumper pack to get the engine running. I believe the battery is defective. The factory warranty is 6 months. Do you think I should be able to get the battery replaced under warranty?
2011 Sportsman 800 EFI
Superwinch Terra 35
Polaris HD front springs
KFI 60" Pro-Series plow
ITP SS212 wheels
25" GBC Grim Reaper tires
01-17-2012, 01:51 AM
Member #2920
Will not hurt to try. Although its recommended to keep batteries on a battery tender if your not riding that much to keep the battery topped off.
 - Polaris 3500 Winch
- Viking Hause Fairlead and Safety Thimble
- Elka Stage 1 Triple Rate Shocks with Rebound
- Front Lock n Ride Storage Box
- WES Lock and Ride Rear Touring Box
- Rotopax Front Storage Fuel Cells
- Hand Warmers
- Garmin GPSMap 62S
- 27" Grim Reapers
- 8000K HID Lights
01-17-2012, 04:17 AM
depends on dealer , good luck
01-17-2012, 04:55 AM
I would say yes.
01-17-2012, 07:35 AM
Member #17647
The longest I've gone is 2 weeks without riding the machine. It is usually started every 2-3 days.
Superwinch Terra 35
ITP SS212 wheels
01-18-2012, 08:39 AM
Member #13820
Sounds like a bad battery, I would take the battery back to the dealer and have them load test it. A battery tender is a good idea in cold temps-those little batteries are fussy. You can get a Schumacher tender at Tractor Supply for about $20. It comes with a pigtail you can attach to the battery for quick hookup.
2011 Sportsman 500 HO
KFI 3000# winch
Ricochet A Arm Armor
Rear Rack
Polaris Front Rack Extender
Viper 60" Plow
Moose Heated Grips
01-18-2012, 08:55 AM
This^
Atv warranty doesn't cover batteries, but yuasa offers a 6 month warranty on their batteries, so you still should be good if you go do it now at the dealer.
01-18-2012, 08:11 PM
Member #17647
I have a trickle charger, but there's no reason to use it when I start the machine every 2-3 days. My old Sportsman 600 would start at -20 without a trickle charger. I rode my 800 yesterday(had to jump start it). If I went out there now, I guarantee it would have to be jumped again. I have an appointment for next Tuesday at the local Polaris dealership.
Superwinch Terra 35
ITP SS212 wheels
2012 polaris sportsman 800 efi battery replacement, 2012 polaris sportsman 800 efi battery tender, best aftermarket battery for 11 sportsman 800, does can-am warranty cover battery, does polaris atv warranty cover battery, does the polaris 6 month warranty cover the batery?, polaris battery for 800 efi, polaris battery warranty, polaris warranty cover batteries, sportsman 600 totally dead below freezing, what battery does polaris atv 850 touring, what does can am atv warranty cover battery, what is the warranty on polaris atv batteries
