Old 01-19-2012, 06:04 PM
Rjbeck77's Avatar
Member #22254
Clean Up
I just bought my first 4 wheeler Saturday and took it out on Sunday and got it pretty dirty. Took it to the car wash and power washed it down to what I think is pretty clean.
I was hoping for some ideas on post riding clean up. What do I need to pay extra attention to? Any chemicals to use or avoid? Any advice to make the process easier? Certain things that are a must clean? Mechanically? Cosmetically?
Thanks in advance
Old 01-19-2012, 06:52 PM
offroadster's Avatar
Member #5616
Look in your owner's manual for lube points. Mine has lube points on the front propellor shaft slip yoke, and I upgraded to greasable u-joints, and the front struts. Be careful with the pressure washer, you can force water into bearings, u-joints, etc. I'd also check the oil in all the gear boxes. It's a bit of work, but can save hundreds in repair bills.
easy atv cleanup
how to clean carb on 04 polaris 600 fourwheeler
how to clean carburetor on a polaris
Can I clean this with a SOS pad? tabnavy ATV Repair and Maintenance 1 11-12-2011 05:18 PM
How do you get the exhaust clean plug out? fredo Polaris Sportsman 4 03-10-2011 03:03 PM
need help to clean out fuel tank texasfight04 Polaris Trail Blazer 4 03-09-2011 01:09 PM
How do I remove my carb to clean it? craigsadams ATV Repair and Maintenance 1 12-08-2010 08:35 AM
Trying to clean my wheeler newrider ATV General Discussion 3 06-08-2009 03:52 AM
