Ok so I said screw it and built my own 3 point hitch setup. I used an old plow that I have for my 1970s Sears Craftsman lawn tractor. I made the upper part first allowing me to access my waterproof storage still. I then went on to making the lower part. I will be reinforcing the actuator support I think.
All the parts you see in the photos can be purchased at any tractor supply.
I made everything from scratch except for the lift arms and top link.
I used chains welded to the lift arms as anti-sway bars and used my receiver pin as the anchor point. I might modify the design and use my hitch that goes in the receiver.
