Old 01-22-2012, 06:21 PM
prospergunman's Avatar
Member #22570
2011 LE 550 EPS Power Steering Problems already
I just picked up a 2011 LE Sportsman 550 EPS on Saturday and took it out today for 2 hours or riding, mostly field, climbing some dirt hills, a little mud and creek bottom riding. Everything was fine until about an hour into riding my EPS stopped working. The battery light came on the display and the power steering light would come on and go off intermittently. I shut it off re-started and the battery light went off and the EPS worked for about 5 minutes and then the same thing happened again. Took it back to the house, power washed it, check the fuses and battery connections and everything looked fine. Started it up again and the battery light was not on and the EPS worked fine...for about 5 minutes and it happened again.
I have read most of the thread about this, but most of them don't say what was wrong and what the dealer did to fix it. I'm pissed I have to load this 2 day old 550 backup and take it back already.
Thanks in advance for the help and great forum!!
Old 01-22-2012, 06:31 PM
Old 01-23-2012, 12:00 AM
bosnjo's Avatar
Member #18373
Check if battery connections are tight enough, before you take it the dealer.
2011 Sportsman Touring 850 EPS
------------- Portugal --------------
- Wind deflectors
- Rear motorcycle box
- Front Brush Guard
- Car tires
- GPS Garmin Dakota 20
- Road legal
Old 01-23-2012, 01:44 AM
Smoothbassman's Avatar
Member #2920
Yes, check battery cables and the connectors going into the EPS unit. Make sure they are tight. also check your ground wire underneath the steering stem. It could be loose as well.
Also check to see if you have any codes being thrown and write them down.
If it persists you will have to drop it back off at the dealer.
  • Polaris 3500 Winch
  • Hand Warmers
  • Garmin GPSMap 62S
  • 27" Grim Reapers
  • 8000K HID Lights
Old 01-23-2012, 04:57 AM
Member #22570
I did check the battery terminal connections and they were tight. I'll check the ground and the connections going into the EPS unit itself.
Would the codes be flashing up on the LCD screen above the battery symbol, or next to the power steering idiot light that was going of and on?
I would love to hear from other members that have had this problem what the dealer has had to repair or replace to resolve this issues.
Old 01-28-2012, 06:12 AM
fredcrideout's Avatar
Member #22010
Same Problems
I had the same problem when I purchased my 2011 Sportsman 550 EPS. After two days the same problems started to occur.
After two months of trouble shooting by the Service Manager it was determined that there was a problem with the Main Wiring Harness. You have to be a bit forceful because my Manager was very reluctant to change out a $545.00 part which also needs 5 - 6 hours of labor to complete the task.
Been riding the bike now for about 2 wks without any issues.
Fred
Old 01-30-2012, 05:15 AM
WalterS's Avatar
Member #12678
I wonder what it was, specifically wrong with the harness?? I'll just bet that the problem area in the harness could be fixed without changing out the entire harness.
Does anybody know?
2007 Sportsman 800
1300 miles, mostly at Hatfield-McCoy trails, WVa.
Old 01-31-2012, 07:06 PM
muddywaters's Avatar
Member #15640
Does anybody know?
Yeah, It's a Polaris.
atv power steering problems
do i need power steering on atv
polaris 550 eps power steering problems
polaris atv power steering problems
polaris power steering problems
polaris sportsman do you need power steering?
polaris sportsman power steering problems
what connectors to check on polaris eps?
when did polaris start with power steering on atvs
Power Steering on an X2 SeanE1987 Polaris XP 22 04-13-2012 03:41 PM
Power steering problems 08GT ATV General Discussion 8 12-19-2011 03:03 PM
Having problems with my power steering on my xp gobucks85 ATV General Discussion 5 10-05-2011 06:48 AM
Can you add power steering swede Polaris Sportsman 1 10-10-2010 05:17 PM
WHY no power steering on the 2011 850 X2 sjcarp Polaris XP 3 09-11-2010 04:21 PM
