Old 01-23-2012, 07:41 AM
ddlawnguy's Avatar
Member #17251
polaris 800 sportsman just dies
Okay well i have applied all of the dielectric grease to all my connection and plugs and sealed my airbox or atleast thought i sealed it. I took it out over the weekend and hit a few holes with her, and this time i got in some deep peanut butter mud, and a little water and once i got stuck it just dwindled down on power and then eventully died. i have to hold the starter over and give it gas just to get it to start back up. eventually got out, but i cant stand how it keep stalling on me when im in the middle of the hole. the mudd and water is up about 2 inches below the seat, so its nothing to drastic. the exhaust is under the water. So when i got back checked the airbox and there is a tiny bit of mud on the bottom of the inside of the airbox. what is the deal???? any help?
2011 Sportsman 800 efi- 2 inch RDC lift, 28in backs, itp ss212 black wheels, polaris front and rear bumpers, polaris 2500 winch, rear rack extender, uni filter, bazooka tube up front, polaris hand guards. Gorillas axles, mods to come: snorkel
Old 01-23-2012, 09:41 AM
lost cause's Avatar
Member #9763
Sounds like something is getting wet. Either electrical or your air intake. Go through and make sure everything is dielectrically greased, especially the spark plug boots. also make sure that your airbox is completely siliconed.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 01-23-2012, 11:44 AM
ddlawnguy's Avatar
Member #17251
i am gonna go back through it, and do everything again!! damn this is aggrivating as hell!!!!
Old 01-23-2012, 03:38 PM
lost cause's Avatar
Member #9763
It definately can get aggrivating. Any little pin hole and water will get in. Problem with these is airbox lid warps a little bit. Take out the gasket that is in the lid, and just fill the rim of the lid with silicon. Then make sure there are no gaps once lid is installed back on the box and let the silicon fully cure. I usually take the airbox out to do this.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
Old 01-23-2012, 04:23 PM
sounds like plug wire boots gettin wet
Old 01-24-2012, 05:22 AM
ddlawnguy's Avatar
Member #17251
yea my airbox is definately warped. i took it out last night, gonna work on it tonight
polaris 800 dies
polaris 800 sportsman stalls
polaris atv dies in water
racks for polaris800 sportsman
sportsman 800 dies
sportsman 800 runs then dies
sportsman dies from
will putting a 2 inch lift under the front of my polaris sportsmen help me in the mud
Engine dies after 2 mins, restarts after 2 mins, dies again, repeat Patriot_RAM ATV Repair and Maintenance 11 01-24-2012 09:26 AM
sportsman 500 dies chuckiedo ATV Repair and Maintenance 2 08-10-2011 09:26 AM
new polaris, starts then dies???? bulldogs101 ATV Repair and Maintenance 6 07-29-2011 07:03 PM
Pure Polaris Winch Dies... Polaris850XP Polaris XP 4 03-01-2011 05:52 AM
700 sportsman dies bailbud ATV Repair and Maintenance 0 08-08-2010 11:03 AM
